I've record some script by Space Claim for creating an easy model.
The script is like below
# Python Script, API Version = V22
# Sketch Circle
plane = Plane.PlaneZX
result = ViewHelper.SetSketchPlane(plane)
origin = Point2D.Create(MM(0), MM(0))
result = SketchCircle.Create(origin, MM(25))
baseSel = SelectionPoint.Create(CurvePoint1)
targetSel = SelectionPoint.Create(DatumPoint1)
result = Constraint.CreateCoincident(baseSel, targetSel)
# EndBlock
# Solidify Sketch
mode = InteractionMode.Solid
result = ViewHelper.SetViewMode(mode, Info1)
# EndBlock
# Extrude 1 Face
selection = Face1
options = ExtrudeFaceOptions()
options.ExtrudeType = ExtrudeType.Add
result = ExtrudeFaces.Execute(selection, MM(200), options, Info2)
# EndBlock
Is there any way that could run the script by using pyMechanical?
mechanical = pymechanical.launch_mechanical
mechanical.run_python_script(xxxxxx)
Can I fulfill mechanical.run_python_script with the space claim script content?
My Ansys running environment is in Linux and version 2023 R1.
