Close WorkBench from WBJN script
Is there a way to exit workbench from a running WBJN script?
I know I can use the -X switch to automatically close WB at the end of the WBJN but I need to run with the -I switch.
Thanks
  • Pierre Thieffry
    @cedev not sure I understand you. -X will run interactively then close, -I will run interactively but not close WB at the end.
    What else do you want to achieve?
  • cedev
    cedev Member Posts: 5
    That did the trick.
    Thank you!
