Retrieve values of standard Mechanical through scripting
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 894
Can we retrieve the values of a standard result in Mechanical through scripting?
In 2020R2 a new feature was introduced to retrieve the values of a native result inserted in the Mechanical tree. For example, you can insert from the Mechanical GUI (or through automation scripting) a Equivalent Stress result, choose the averaging option, and then retrieve the values:
standardVonMises=ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddEquivalentStress() # insert Equivalent Stress result through automation standardVonMises.DisplayOption=ResultAveragingType.Averaged # change averaring option standardVonMises.EvaluateAllResults() # evaluate plotData=standardVonMises.PlotData # retrieve plot data -> for averaged option, returns an object containing list of body ids, node numbers, and values. plotData[0] # list of body ids plotData[1] # list of node ids plotData[2] # list of values
For example, if plotData.Values[1][0] returns 159 and plotData.Values[2][0] returns 2.7287E+08 then you know that averaged equivalent stress on node 159 is 2.7287E+08 Pa.
