Adding nonlinear bushing joints via Mechanical scripting
Jimmy He
Jimmy He Member, Employee Posts: 27
I would like to create nonlinear bushing joints with Mechanical scripting. When I turn on recording, I can see the commands to insert a joint, set the type and scoping, but it does not show the command to run the stiffness entries to tabular in Mechanical so nonlinear coefficients can be entered.
I understand that nonlinear stiffness behavior can be activated via APDL command snippet, which can be added via scripting. This worked for me in the past for a revolute joint, where I was able to insert a revolute joint with default 0 stiffness, then overwrite its stiffness behavior via APDL snippet. The issue with bushing joint is that Mechanical writes out a "TB,JOIN,_jid,,,STIFF" line to the input file by default when the bushing joint object is inserted (this is not the case for a revolute joint). Since the STIFF keyword cannot co-exist with the JNS keywords needed for nonlinear stiffness coefficients, I cannot overwrite it via APDL snippet either.
Any suggestions and comments are welcome!
  • Abel Ramos
    Abel Ramos Member, Employee Posts: 43
    Second Anniversary 5 Answers 10 Comments 5 Likes
    I think something in this like should work. However, please be aware that InternalObject is "not officially supported", so you may encounter some unexpected behavior.
    joints = ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.Joint)
    bush=joints[0]
    bush.InternalObject.ActiveNonlinearCell(0,0) #First Cell, Next Cells (1,1),(2,2)
    bush.InternalObject.JointNonlinearCell("_EnggData_Table",1,1)
    paneTabular = ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData)
    control = paneTabular.ControlUnknown
    #Displacements
    cell = control.cell(2,2)
    control.TriggerBeforeEdit(cell)
    cell.Text = str(1) #Cell Value
    cell.Refresh()
    control.TriggerAfterEdit(cell)
    control.InsertRow
    cell = control.cell(3,2)
    cell.Text = str(2) #Cell Value
    cell.Refresh()
    #Forces
    cell = control.cell(2,3)
    cell.Text = str(10) #Cell Value
    cell.Refresh()
    control.InsertRow
    cell.Text = str(20) #Cell Value
    cell.Refresh()
  • Kev
    Kev Member Posts: 43
    Hi @**Abel Ramos how would one go about accessing the dampoing coefficeints table just below the stiffness table? would you know by any chance ?
    I managed to populate all **the stiffness coefficient with tables successfully however I am still getting the error saying basically only tabular data is allowe after enabling nonlinear cells. I suspect that it is expecting tabular data for all the enable damping cells as well. Thoughts?
