Change in Equivalent Plastic Strain
Mateo
Mateo Member Posts: 2
Hi there,
I want to plot results in Ansys which can show the change in Equivalent Plastic Strain between the current increment and the previous increment. Something similar to Accumulated Plastic Strain, but instead of summing the values, I want to substract them. I will have around 100 steps, so I want to have it automated and be able to summarize the results in tabular data for each step.
Could anyone help me with this?
  • Erik Kostson
    edited June 2024
    Hi
    Perhaps you can insert results with identifiers and then create a user defined result to subtract the results as needed (see here: https://www.youtube.com/watch?v=X-LV48DYn_s)
    This can be automated I suppose as needed - you can use recording to create a script.
    all the best
    Erik
  • Mateo
    Hi Erik,
    thank you for your comment, highly appreciate that.
    Actually, I came up with this idea but I find it laborious in cases I have many steps/increments. Do you know if it's possible to write a command in APDL which works as following:
    deltaEPPLEQV = EPPLEQV(s) - EPPLEQV(s-1)
    where:
    EPPLEQV is the Equivalent Plastic Strain,
    s is the current step,
    s - 1 is the previous step.
    So basically I want to create a result which shows an increase in Equivalent Plastic Strain.
    Cheers,
    Mateo
  • av
    av Member Posts: 10
    Hi Mateo,
    does this code help you? (please check the results, whether they are what you wanted)
    edit index to generate the results in the right modul
    index = 0
    n_of_sets = Model.Analyses[index].GetResultsData().ResultSetCount
    postmodul = ExtAPI.DataModel.Project.Model.Analyses[index].Solution
    eppl_result_list = []
    for i in range(1,n_of_sets+1):
    eppl = postmodul.AddEquivalentPlasticStrain()
    eppl_result_list.append(eppl)
    eppl.By = SetDriverStyle.ResultSet
    eppl.SetNumber = i
    eppl.CalculateTimeHistory = 0
    eppl.Identifier = 'eppleqv_'+i.ToString()
    eppl.Name = 'eppleqv_'+i.ToString()
    myGroup = ExtAPI.DataModel.Tree.Group(eppl_result_list)
    myGroup.Name = "Equivalent plastic strain"
    udr_result_list = []
    for i in range(1,n_of_sets):
    udr = postmodul.AddUserDefinedResult()
    udr_result_list.append(udr)
    udr.Name = "eppleqv_"+(i+1).ToString()+"-"+"eppleqv_"+(i).ToString()
    udr.Expression = "eppleqv_"+(i+1).ToString()+"-"+"eppleqv_"+(i).ToString()
    myGroup = ExtAPI.DataModel.Tree.Group(udr_result_list)
    myGroup.Name = "Equivalent plastic strain increment"
    postmodul.EvaluateAllResults()
    Greetings,
    av
  • av
    av Member Posts: 10
    Hi Mateo,
    please edid the variable "index" to get the results in the right modul
    index = 1
    eppl.SetNumber = i
    Greetings,
    av
