How to create a nodal displacement on a named selection?
Pernelle Marone-Hitz
Adapt the following code:
analysis = ExtAPI.DataModel.Project.Model.Analyses[0] nodal_disp = analysis.AddNodalDisplacement() # Add BC nodal_disp.Location = ExtAPI.DataModel.GetObjectsByName('Nodal_NS')[0] # Note: GetObjectsByName method returns a list of all tree elements with a specific name. # If the name is unique, it is a convenient method to grab tree objects # Define X values through tabular data nodal_disp.XComponent.Inputs[0].DiscreteValues =[Quantity('0.5[s]'), Quantity('1[s]')] nodal_disp.XComponent.Output.DiscreteValues =[Quantity('0[mm]'), Quantity('1[mm]')] # Define Y values through tabular data nodal_disp.YComponent.Inputs[0].DiscreteValues =[Quantity('0.5[s]'), Quantity('1[s]')] nodal_disp.YComponent.Output.DiscreteValues =[Quantity('0[mm]'), Quantity('0[mm]')] # Define Z values through tabular data nodal_disp.ZComponent.Inputs[0].DiscreteValues =[Quantity('0.5[s]'), Quantity('1[s]')] nodal_disp.ZComponent.Output.DiscreteValues =[Quantity('0[mm]'), Quantity('2[mm]')]
