In the given design only one sphere is solidified but I want to solidify all of them and intersect with outer cube design. i want also naming selection in which want to give porous name to all spheres and domain to remaining(excluding spheres) part
Are these spheres not solids to start with? What do you mean by solidify? You can use the interference tool to remove the spheres from the enveloping cube. Do it in the UI and record it to start with.
basically i want to group all spheres to give a "porous" name. but now I am doing this but there is problem
Create Named Selection Group
primarySelection = BodySelection.Create(Body4, Body5, Body6, Body7, Body8, Body9, Body10, Body11, Body12, Body13, Body14, Body15, Body16, Body17, Body18, Body19, Body20, Body21, Body22, Body23, Body24, Body25, Body26, Body27, Body28, Body29, Body30, Body31, Body32, Body33, Body34, Body35, Body36, Body37, Body38, Body39, Body40, Body41, Body42, Body43) secondarySelection = Selection.Empty() result = NamedSelection.Create(primarySelection, secondarySelection)
Rename Named Selection result = NamedSelection.Rename("Group1", "porous")
here each sphere has his own Body and when I run a loop so I don't know how many sphere will be generated so each time all spheres won't be selected
sel = Selection.Create(Body) sel.CreateAGroup("porous") I want to do like this
please help it's very urgent
