Export Mesh in Local Coordinate System
Georges Vacher
Georges Vacher Member Posts: 3
First Comment Photogenic
Hello
In mechanical scripting, is there a simple method to get mesh coordinates in a local coordinate system (cartesian).
Do I have to program the transformation myself or can I use some already programmed methods ?
I found something with 4x4 matrix, but I'm too old for that ...
Thanks
  • Georges Vacher
    Oups sorry
    It was quite easy to do with csys.matrix...
    Just surprised there is no method to do this natively
    bye
    FYI you can use some DPF operators to rotate data to a given CS (matrix).
    import mech_dpf
    def RotationMatrixFieldFromCS(CsName):
    CS = ExtAPI.DataModel.GetObjectsByName(CsName)[0]
    CsMatrix = list(CS.Matrix)
    TransformMatrix = [CsMatrix[i] for i in [0,3,6,1,4,7,2,5,8]]
    rot_mat_f = dpf.FieldsFactory.CreateScalarField(1)
    rot_mat_f.Data = TransformMatrix
    return rot_mat_f
    def RotationOperatorFromCs(CsName, FieldsContainer):
    rot_mat_f=RotationMatrixFieldFromCS(CsName)
    RotateOp = dpf.operators.geo.rotate_fc() # operator instantiation
    RotateOp.inputs.fields_container.Connect(FieldsContainer)
    RotateOp.inputs.coordinate_system.Connect(rot_mat_f)
    return RotateOp
    def AlignFieldToCs(CsName, FieldsContainer):
    Take a field and align it to a local CS in Mechanical by its Name
    RotateOp=RotationOperatorFromCs(CsName, FieldsContainer)
    RotField=RotateOp.outputs.fields_container.GetData()
    return RotField
    def ObjByName(Name):
    return ExtAPI.DataModel.GetObjectsByName(Name)[0]
  • Georges Vacher
    Thanks Mike for this method.
    I'm not familiar with DPF, but I'll try to learn how to use it.
