Error While Launching launch_mapdl() function
Naveen Kumar Begari
Member Posts: 106
@Naveen Kumar Begari said:
Is anyone else having this problem?@Chris Harrold Can I get assist on this..?
@Chris Harrold @Naveen Kumar Begari I'm helping Naveen with this on I think a direct discussion.
Mike1 -
Thanks, @Mike Rife! Will you provide the details back here when you get it sorted?
1 -
Sure thing @Chris Harrold
The "most usual suspect", IMO, would be that the file that cannot be found is the MAPDL executable. So the first thing to check is 1) do the environment variables exist that hold the path info 2) if they env vars do exist do they hold the right path(s) or 3) does PyMAPDL have cached an outdated path.0 -
Morning @Mike Rife ,
Updated in private msg.0
