wrong stress gradient?
lmbx2517
lmbx2517 Member Posts: 2
I have the problem that the stress value (max. stress according to Mises) at the surface (Fig. 1, 334.47 MPa) does not match the evaluation of a path (Fig. 2, 343.33 MPa). The start of the path is at the same node as in Fig. 1 and extends vertically 10 mm into the component. 100 points along the path are considered. Furthermore, the course of the gradient within the first support points is strange. Both stresses are according to Mises, and the loadstep also matches.
It would be nice if you could help me. Thank you very much!
    This forum is for scripting questions. Please look into Ansys Innovation Space for general modeling forums
  • lmbx2517
    Could this thread be deleted then?
  • Erik Kostson
    Does not seem it can be deleted (a whole post) - that would be a great enhancement @James Derrick also to be able to delete a comment made :)
  • Erik Kostson
    Does not seem that it can also comments can not be deleted - would be a great enhancement to this site @James Derrick
  • James Derrick
    James Derrick Administrator, Employee Posts: 379
    admin
    @Erik Kostson and @lmbx2517 you can flag comments and threads with the "flag" button
    and this will flag them to moderators that can delete them :)
  • Erik Kostson
    Can not delete posts or comments unfortunately - perhaps @James Derrick , this can be improved
  • Erik Kostson
    edited August 2024
    Thank you - I have flagged before and nothing happened so just remained there as it was not picked up likely - also the Post comment button is not working well (needs to be pressed several times or there is some lag between press and published comment also a strange message appears at the bottom left of the browser window). Comments/Answers are now put at the top rather than last like before :)
