how to give name selection separately like rectangle_porous to all rectangles and circle_porous to all circle in a given design using script in spaceclaim.
anyone, please help
Creating a named selection can easily be recorded in the scripting console. Once you have this recording, the problem seems to be reduced to how to select the individual geometric entities. You will need to decide if you want bodies vs. faces. (not sure if they are distinct bodies or not).
You could use something like this to loop through all the currently selected items and make distinct NS for each. for Entity in Selection.GetActive().Items: EntSel = Selection.Create(Entity) #Create your NS here with the selection from above.
