I am trying to run a post-processing script for my thermal results that uses Numpy and Scipy libraries.
However, those are not available in the ANSYS 2021 version, so I am trying to do that by using a Python Code obejct in the interface that calls my post-processing script via a command window.
Sadly, I am a bit lost as the script does not seem to be running even though no error message appears.
I'all appreciate your help.
Thank you
