How to export results on all bodies with DPF in Mechanical
Mike.Thompson
How can I export results data (i.e. temperature) for all bodies to their own files also with data like max and min at each time point?
    See this example that contains a python code object. Run the solve and .csv files will be generated in the solution directory.
    Code below:
    import mech_dpf
    from os.path import join
    mech_dpf.setExtAPI(ExtAPI)
    def after_solve(this, analysis):# Do not edit this line
    #Get some basic data
    DataSource=dpf.DataSources(analysis.ResultFileName)
    DpfModel = dpf.Model(analysis.ResultFileName)
    #Time scoping on all the result sets of the results file.
    TimeScoping = dpf.TimeFreqScopingFactory.ScopingOnAllTimeFreqs(DpfModel)
    TimeScoping.Ids=list(TimeScoping.Ids)[:-1]
    #get all the temperature data
    Temp_op=dpf.operators.result.temperature()
    Temp_op.inputs.time_scoping.Connect(TimeScoping)
    Temp_op.inputs.data_sources.Connect(DataSource)
    Temp_FC=Temp_op.outputs.fields_container.GetData()
    #Get the mesh nodal scoping of all the active bodies
    Bodies = ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.Body)
    ActiveBodies = filter(lambda B: B.Suppressed==False, Bodies)
    for B in ActiveBodies:
        #get the nodal mesh scoping per body
        SelInfo = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities)
        SelInfo.Ids=[B.GetGeoBody().Id]
        BodyMeshScoping=mech_dpf.GetNodeScopingByRefId(SelInfo)
        #Do a subset of the total temperature data
        op = dpf.operators.scoping.rescope_fc()
        op.inputs.fields_container.Connect(Temp_FC)
        op.inputs.mesh_scoping.Connect(BodyMeshScoping)
        op.inputs.default_value.Connect(0)
        Body_FC = op.outputs.fields_container.GetData()
        #Write this info to a .csv file
        CSV_op=dpf.operators.serialization.field_to_csv()
        CSV_op.inputs.field_or_fields_container.Connect(Body_FC)
        CSV_op.inputs.file_path.Connect(join(analysis.WorkingDir, B.Name+"_Temperatures.csv"))
        CSV_op.Run()
        #get the min and max.  result will be a min and max field with Time as Ids and a single value (min or max)
        MinMax_op= dpf.operators.min_max.min_max_fc()
        MinMax_op.inputs.fields_container.Connect(Body_FC)
        BodyMax_F=MinMax_op.outputs.field_max.GetData()
        BodyMin_F=MinMax_op.outputs.field_min.GetData()
        #Write this to .csv files as well.
        CSV_op.inputs.field_or_fields_container.Connect(BodyMax_F)
        CSV_op.inputs.file_path.Connect(join(analysis.WorkingDir, B.Name+"_Max.csv"))
        CSV_op.Run()
        CSV_op.inputs.file_path.Connect(join(analysis.WorkingDir, B.Name+"_Min.csv"))
        CSV_op.Run()
