How can i add the variable Mach number to the window results?
AlainJesus_10
AlainJesus_10 Member Posts: 1 **
For ansys R2022 is available. But i think for the new version R2024 we should introduce it and i cant find how.
  • dnwillia
    dnwillia Member, Employee Posts: 4
    Second Anniversary First Comment Photogenic Ansys Employee
    edited July 2024
    You can do it in CFD Post but you will have to define an expression for the speed of sound in the "Expressions" tab. i.e something like c = sqrt(gamma*R*Temperature) and then M = Velocity/c. You would be able to plot "M" after doing that.
    If you use Fluent for post processing then the expressions are not needed.
