How to run all the Verification Manual examples using PyMAPDL?
Rohith Patchigolla
I would like to run all the VM examples one after the another using a single license. Is it possible?
  • Rohith Patchigolla
    One could try using the below script to run through all the verification manual examples in PyMAPDL.
    from ansys.mapdl.core.examples import vmfiles
    #Inputs
    #Path where the outputs for each VM are saved
    savepath = r"D:\Python\vm_output"
    #First and last VMs to solve
    start_vm = 1
    end_vm = 320
    mapdl = launch_mapdl()
    for vm_num in range(start_vm,end_vm+1):
        mapdl.clear()
        print("vm"+str(vm_num))
        output = mapdl.input(vmfiles["vm" + str(vm_num)])
        filename = "output_vm_" + str(vm_num) + ".txt"
        fullpath = os.path.join(savepath,filename)
        with open(fullpath, "w") as file:
            file.write(output)
        mapdl.finish()
    mapdl.exit()
