Mechanical DPF - how to obtain pipe and elbow APDL element type
I was trying to obtain APDL element type based on the element ID. For regular scripting I was able to obtain it using the following lines of code.
reader_PNUMENAM = reader.GetResult("PNUM") PNUMENAM = reader_PNUMENAM.GetElementValues(element_id)[6]
I use it to differentiate what SMISC values should the script use to extract necessary input for Piping stress calculations. PIPE288,PIPE289 and ELBOW290 use different SMISC to get forces, moments or pressure values.
I could not find a way to get the data similarly to the reader above, so I've tried to create myself a dictionary that couples the element_Id and apdl_element_type... but it seems it does not recognise PIPE or ELBOW elements at all. My model consists of Beam, Pipe and Shell elements - I can obtain the element types like 181, 188, 170 but no 288, 289, 290. I know in the previous versions of Ansys, PIPE elements were not supported for SMISC extraction, but now in 2023R2 they do work fine.
import mech_dpf import Ans.DataProcessing as dpf analysis_id = 0 model = ExtAPI.DataModel.Project.Model analysis = model.Analyses[analysis_id] rst_path = r"{}file.rst".format(analysis.Solution.ResultFileDirectory) dataSource = dpf.DataSources() dataSource.ResultFilePath = rst_path my_model = dpf.Model(rst_path) my_mesh = my_model.Mesh apdl_type = my_mesh.GetPropertyField("apdl_element_type").Data all_element_Ids = my_mesh.ElementIds element_dict = {} for element_Id, apdl_element_type in zip(all_element_Ids,apdl_type): element_dict[element_Id] = apdl_element_type
I've just check with 24R1. PIPE288, PIPE289 and ELBOW290 elements are still not available for DPF.
@Mateusz Some element types are not yet available in DPF. Could you please open an issue on Github?
