The script in Spaceclaim encountered an error in the ACT Stage Page
zggnph
zggnph Member Posts: 7
I developed a script that can run on SpaceClaim, but when the script is integrated into the ACT Stage Page, the following error is reported.
  • Landon Mitchell Kanner
  • zggnph
    This operation has already been executed, still reporting this error.
    edited July 2024
    Try this:
    import os, sys
    clr.AddReference("Ans.Utilities")
    from Ansys.Utilities import ApplicationConfiguration
    version = ApplicationConfiguration.DefaultConfiguration.VersionInfo.VersionString
    sys.path.append(os.environ["AWP_ROOT"+version]+"/scdm/Scripting")
    clr.AddReference("SpaceClaim.Api.V{}".format(version))
    clr.AddReference("SpaceClaim.Api.V{}.Scripting".format(version))
    exec('from LoadSCDMAPITypesV{} import *'.format(version))
    exec('from UtilitiesOnLoadV{} import *'.format(version))
    exec('from SpaceClaim.Api.V{}.Scripting import Extensions'.format(version))
    exec('arg = SpaceClaim.Api.V{}.Scripting.Extensions'.format(version))
    clr.ImportExtensions(arg)
    GetRootPart().GetComponents()
    If it works on your end, I will file a bug to add:
    from SpaceClaim.Api.V241.Scripting import Extensions
    clr.ImportExtensions(SpaceClaim.Api.V241.Scripting.Extensions)
    to LoadSCDMAPITypesV241.py
  • zggnph
    @Landon Mitchell Kanner said:
    Try this:
    import os, sys
    The problem has been solved using this method, thank you.
    The Ansys team has decided not to fix this bug, because there is a workaround and because SpaceClaim and SpaceClaim ACT are in maintenance mode. We recommend starting to transition SpaceClaim ACT usage to the Discovery customization functionality, which uses the same script editor and provides more functionality, including an extension builder.
