Get original and deformed lengths of paths in Mechanical
Jimmy He
Member, Employee Posts: 28
I need a create a path in Mechanical and measure its original and deformed lengths, how can I achieve this via scripting?
After a path is created, you can select the path and use the following script:
import clr clr.AddReference("System.Windows.Forms") clr.AddReference("System.Drawing") from System.Windows.Forms import MessageBox obj = Tree.ActiveObjects[0] solution = DataModel.AnalysisList[0].Solution dirs = [ NormalOrientationType.XAxis , NormalOrientationType.YAxis , NormalOrientationType.ZAxis ] def Distance( a , b ): return ( ( a[0] - b[0] )**2 + ( a[1] - b[1] )**2 + ( a[2] - b[2] )**2 )**0.5 with Transaction(True): # Create results directional_deformation = solution.AddDirectionalDeformation() directional_deformation.ScopingMethod = GeometryDefineByType.Path directional_deformation.Location = obj data = [] unit = '' for d in range( 3 ): directional_deformation.NormalOrientation = dirs[d] directional_deformation.EvaluateAllResults() pd = directional_deformation.PlotData if d == 0: data.append( pd['X Coordinate'] ) data.append( pd['Y Coordinate'] ) data.append( pd['Z Coordinate'] ) v = pd['Values'] unit = v.Unit data.append( list(v) ) # Calculate lengths length_old , length_new = 0. , 0. for i in range( len(data[0]) ): # Calculate deformed coords for j in range( 3 ): data[ 3 + j ][ i ] += data[ j ][ i ] # Calculate segment lengths if i > 0: p1 = [ data[0][i] , data[1][i] , data[2][i] ] p2 = [ data[0][i-1] , data[1][i-1] , data[2][i-1] ] length_old += Distance( p1 , p2 ) p1 = [ data[3][i] , data[4][i] , data[5][i] ] p2 = [ data[3][i-1] , data[4][i-1] , data[5][i-1] ] length_new += Distance( p1 , p2 ) # Get current units used in Mechanical L_unit = DataModel.CurrentUnitFromQuantityName("Length") length_old = Quantity( length_old , unit ).ConvertUnit( L_unit ) length_new = Quantity( length_new , unit ).ConvertUnit( L_unit ) MessageBox.Show('Original path length = ' + str(length_old) + '\nDeformed path length = ' + str(length_new))
