How to create dataset using PyAEDT?
ansys-satyajeet
ansys-satyajeet Member, Employee Posts: 14
Second Anniversary Photogenic Ansys Employee First Comment
How to create a project and design dataset in AEDT using PyAEDT?
Best Answers
  • ansys-satyajeet
    edited July 2024 Answer ✓
    Start by importing pyaedt.
    import pyaedt
    Start an Icepak session by inserting a new Icepak design
    ipk = pyaedt.Icepak(project="create_datasets.aedt", design="new_design",
                        version=2024.2, new_desktop=True)
    Create design and project dataset names
    design_dataset = "design_dataset"
    project_dataset = "project_dataset"
    When using project dataset, a "$" sign must be added as prefix.
    project_dataset_name = "$" + project_dataset
    In this example, a dataset for temperature-dependent thermal conductivity is created. Temperature (x-axis) has units of cel and thermal conductivity (y-axis) has units of W_per_Kelm.
    temp = [0.28, 11.16, 22.03, 35.74, 50.87,
            75.94, 100.54, 142.17, 159.20, 199.89,
            225.93, 271.36, 300.70, 327.20]
    k = [179.62, 170.08, 159.27, 149.74, 138.29,
         126.23, 114.17, 100.22, 93.24, 85.03,
         79.97, 73.04, 67.99, 63.57]
    To create a project dataset use the following code lines. The code checks if a dataset with same name is already present, if not, a new dataset is created.
    if project_dataset_name not in ipk.project_datasets.keys():
        ipk.create_dataset1d_project(project_dataset, x=temp, y=k, x_unit="cel", y_unit="W_per_Kelm")
    To create a design dataset use the following code lines
    if design_dataset not in ipk.design_datasets.keys():
        ipk.create_dataset1d_design(design_dataset, x=temp, y=k, x_unit="cel", y_unit="W_per_Kelm")
    Release AEDT session using the following command.
    ipk.release_desktop(close_projects=True, close_desktop=True)
  • ansys-satyajeet
    import pyaedt
    Start an Icepak session.
                        version=2024.1, new_desktop=True)
    Set design and project dataset names
    List of temperature (x-axis) with units of cel
    List of thermal conductivity (y-axis) with units of W_per_Kelm
    Create a project dataset. The if condition is used to check if the dataset already exists, if not, then create a new dataset.
    Create a design dataset
    Release AEDT desktop session
