PyEDB: how to get minimum via diameter?
ansys-satyajeet
ansys-satyajeet Member, Employee Posts: 14
Second Anniversary Photogenic Ansys Employee First Comment
How to get min via diameter in an ECAD using PyEDB?
  • ansys-satyajeet
    edited July 2024
    Start with import pyedb which is a python library to handle ECAD files.
    import pyedb
    Import ECAD using pyedb. The session is run in a non-graphical mode.
    edb = pyedb.Edb(ecad_path, edbversion=2024.2)
    Get the min via diameter using the following lines
    unique_padstack_defs = {via.padstack_definition for via in edb.padstacks.vias.values()}
    min_via_dia = min(edb.padstacks.definitions[name].hole_diameter for name in unique_padstack_defs)
    Close the edb session
    edb.close()
  • svandenb-dev
    svandenb-dev Member, Employee Posts: 10
    10 Comments Second Anniversary Ansys Employee First Answer
    Thanks @ansys-satyajeet,
    I guess you posted this code for sharing the information ?
    If you are interested I can also add you as contributor in PyEDB and you could write examples on PyEDB online doc. Thanks
