Getting No valid Ansys Prime Server found to launch error
Suneel
Suneel Member Posts: 13
I am trying to run one of tutorial (https://prime.docs.pyansys.com/version/stable/user_guide/surfer.html) on PyPrime meshing for surface mesh generation. I am getting following error when I am trying to run the code
Help me to resolve the issue.
Regards,
Suneel
  • Alan Varghese
    Alan Varghese Member, Employee Posts: 4
    Second Anniversary First Comment Ansys Employee Solution Developer Community of Practice Member
    Hi ,
    This error could arise due to to reasons ,
    Client and Server version mismatch
    Can you check the client and server versions are matching , you can refer to the following document
    https://prime.docs.pyansys.com/version/stable/getting_started/index.html
    Ansys PyPrimeMesh server executables missing
    Within the Ansys unified installed directory , there should be folder namely meshing . This can be located as follow
    Assuming you have 2024 R2 installed , the following path should exist
    C:\Program Files\ANSYS Inc\v242\meshing
