Hello everyone I want simulate a compressor in room environment, its acoustics effects on room?
vikas sablaniya
Member Posts: 1 **
Hi @vikas sablaniya , welcome to the forum and thanks for posting! Unfortunately, your question is a bit too open ended for the forum. If you think a specific example would be helpful in the documentation of a particular Python library we recommend heading over to the GitHub and making a proposal there, or otherwise coming to us with a MCVE/specific problem about a library that we can help you with.
If none of these options are what you need then you might have some luck heading over to the Ansys Learning Hub Forum, or otherwise contacting your Ansys support rep.
