Title: Ansys 2023R2 RSM Calculation Error - Need Help
Hello everyone,
I've recently updated my Ansys setup to version 2023R2 and consequently updated the server on which I run calculations through RSM. I have configured everything in the RSM configuration and set up Mechanical for RSM execution. However, when I launch the calculation, it appears to be sent to the server (the flame icon changes from yellow to green), but then after 2 seconds, a red arrow appears, indicating that the calculation has failed.
When I try to download the data, the solver output in Mechanical is empty—a blank screen. So, I went to the job monitoring in Workbench and looked for the logs of the failed calculation. I found this part of the error highlighted in orange.
What does this indicate? How should I proceed? I couldn't find anything on the internet.
Hello, this forum is dedicated to scripting questions. To get help on any other topic, please use this other forum instead: https://innovationspace.ansys.com/forum/ or contact your local Ansys support provider. Thank you.
