How to transfer loads and boundary conditions from one analysis to all other analyses in the tree?
Rohith Patchigolla
Rohith Patchigolla Member, Moderator, Employee Posts: 253
I have 4 analyses in Mechanical. I have defined some loads and boundary conditions. How can I use scripting to transfer these loads and boundary conditions from this analysis to all the remaining analyses?
  • Rohith Patchigolla
    You can try using the below script (tested in 2022R2 and above).
    Steps:
    1. Select (multiselect) all the loads and boundary conditions under a particular analysis.
    2. Paste the below script in Mechanical scripting console and run it.
    import context_menu
    #Copy the active Boundary Condition/s
    context_menu.DoEditCopy(ExtAPI)
    parentAnalysis = Tree.FirstActiveObject.Parent
    for analysis in DataModel.AnalysisList:
        if analysis.ObjectId != parentAnalysis.ObjectId:
            print analysis.Name
            analysis.Activate()
            context_menu.DoEditPaste(ExtAPI)
    1. All the loads and boundary conditions will be pasted into other analyses.
  • Erik Kostson
    edited July 2024
    Another way without using and importing external libraries/modules (context_menu), and that uses only ACT mechanical scripting could be using the below code. It 'copies' the selected load (force), pressure, thermalcondition and support (fixed support) from the main/base analysis to other analysis systems that share data with the base one. The below code can be easily extended using the same logic for other load types (e.g., displacements)
    myo=Tree.FirstActiveObject
            print analysis.Name
            analysis.Activate()
            if str(myo.GetType()) == 'Ansys.ACT.Automation.Mechanical.BoundaryConditions.Force':
                f=analysis.AddForce()
                f.Location=myo.Location
                f.AppliedBy=myo.AppliedBy
                f.Magnitude.Inputs[0].DiscreteValues=myo.Magnitude.Inputs[0].DiscreteValues
                f.Magnitude.Output.DiscreteValues=myo.Magnitude.Output.DiscreteValues
            elif str(myo.GetType()) == 'Ansys.ACT.Automation.Mechanical.BoundaryConditions.FixedSupport':
                d=analysis.AddFixedSupport()
                d.Location=myo.Location
            elif str(myo.GetType())== 'Ansys.ACT.Automation.Mechanical.BoundaryConditions.Pressure':
                f=analysis.AddPressure()
            elif str(myo.GetType())== 'Ansys.ACT.Automation.Mechanical.BoundaryConditions.ThermalCondition':
                f=analysis.AddThermalCondition()
            else:
                print('No force or fixed support is selected')
    Hi @Erik Kostson , thanks for posting this answer.
    Just for reference, there might be some limitations with this method.
    An example is a scenario where there are some deactivations in the tabular data of the load, especially inertial loads such as acceleration, rotational velocity etc, as currently there is no API to get this information and hence exactly replicate the load in a new analysis.
    Also, depending on the load, we might have additional settings (other than scoping and magnitude) which may only be accessible via InternalObject or Property.InternalValue.
  • Erik Kostson
    edited July 2024
    Thank you. Very good description
