Running Additive Print simulations via PyAdditive
JackDevine
Member Posts: 1
Reading through the documentation and examples for PyAdditive, it seems that only Additive Science simulations are available as Simulation Types. Is it possible to run an Additive Print simulation (Assumed Strain, Scan Pattern, Thermal Strain) via PyAdditive or any other Python module?
Hello, you should be able to use pyMechanical to setup the Additive case within a Mechanical Project.
Best Regards,
