I have a model with two materials and shared topology. So the nodes between the two bodies are shared.
Node 13 is a corner node between the two geometries.
Due to material props, you can get different strains at the node so Mechanical returns two values for a equivalent strain at node 13.
**My goal is to get the value for equivalent strain at node 13 for material 1 (or 2). **
I tried to use a named selection w/ boolean (material - convert to nodes - filter to node 13 and scope to that name selection but that gives the same results as node 13 direct).
The result I want is best demonstrated by picking a non shared topo node where a single value is returned because there is only one material.
The op = dpf.operators.scoping.split_on_property_type() should allow me to scope to a material (by number) but I don't have it working yet.
first attempts with dpf which get me the averaged nodal result:
define_dpf_workflow(analysis)
# Uncomment this function to enable retrieving results from the table/chart
# def table_retrieve_result(value):# Do not edit this line
# import mech_dpf
# import Ans.DataProcessing as dpf
# wf = dpf.Workflow(this.WorkflowId)
# wf.Connect('contour_selector', value)
# this.Evaluate()
import mech_dpf
node = 13
my_data_sources = dpf.DataSources(analysis.ResultFileName)
my_time_scoping = dpf.Scoping()
my_time_scoping.Ids = [1] # the first set
my_scoping = dpf.Scoping()
my_scoping.Location = "Nodal" #optional
my_scoping.Ids = [node]
st_eqv_op = dpf.operators.result.elastic_strain_eqv()
st_eqv_op.inputs.requested_location.Connect('Nodal')
st_eqv_op.inputs.data_sources.Connect(my_data_sources)
st_eqv_op.inputs.time_scoping.Connect(my_time_scoping)
st_eqv_op.inputs.mesh_scoping.Connect(my_scoping)
#mesh_op = dpf.operators.mesh.mesh_provider()
#mesh_op.inputs.data_sources.Connect(my_data_sources)
#mesh = mesh_op.outputs.mesh.GetData()
op = dpf.operators.scoping.split_on_property_type() # operator instantiation
#op.inputs.mesh_scoping.Connect(st_eqv_op)# optional
#op.inputs.mesh.Connect(mesh)
#op.inputs.requested_location.Connect(13)
dpf_workflow = dpf.Workflow()
dpf_workflow.Add(st_eqv_op)
dpf_workflow.SetOutputContour(st_eqv_op)
dpf_workflow.Record('wf_id', True)
@Vishnu @Pierre Thieffry @Ayush Kumar
