How can we check the contact state and flip contact/target sides if needed?
Pernelle Marone-Hitz
With Mechanical scripting, how can we check the contact state and flip contact/target sides if needed?
    The following function will check the contact state (well defined or unfulfilled) and flip contact/target sides if needed:
    def CheckContactState(body):
          ExtAPI.Log.WriteMessage("Checking contact status due to changing "+ str(body.Name) + "to rigid body")
          contactRegions = ExtAPI.DataModel.Project.Model.GetChildren[Ansys.ACT.Automation.Mechanical.Connections.ContactRegion](True)
          for contactRegion in contactRegions:
              if contactRegion.State==Ansys.ACT.Interfaces.Common.State.Unfulfilled :
                  contactRegion.FlipContactTarget()
  • Happy Kumar
    Happy Kumar Member Posts: 17
    Hi Pernelle, please explain how this scripts works as I am not able see any difference in contact and target.
    Hi @Happy Kumar , this script will reverse contact/target only if the contact is unfulfilled (blue question mark next to the contact). If it is well defined (green tick mark) it will do nothing.
  • Happy Kumar
    Thanks, Pernelle for your response :)
