How can I check whether mesh is linear or quadratic through Mechanical scripting?
The following function can be used:
def LinearQuadraticMesh(analysis): ''' Check whether linear or quadratic elements are used, for beams, shells and solids ''' meshData = analysis.MeshData elemList = meshData.Elements existLinearBeamElements = False existQuadraticBeamElements = False existLinearShellElements = False existQuadraticShellElements = False existLinearSolidElements = False existQuadraticSolidElements = False analysis = ExtAPI.DataModel.Project.Model.Analyses[0] meshData = analysis.MeshData elemList = meshData.Elements for part in ExtAPI.DataModel.Project.Model.Geometry.Children: for body in part.Children: if body.Suppressed is False: geoBody = body.GetGeoBody() if geoBody.BodyType.ToString() == "GeoBodyWire": for elem in elemList: elemType = elem.Type if elemType == ElementTypeEnum.kBeam3 and existLinearBeamElements is False: existLinearBeamElements = True elif elemType == ElementTypeEnum.kBeam4 and existQuadraticBeamElements is False: existQuadraticBeamElements = True else: pass elif geoBody.BodyType.ToString() == "GeoBodySheet": for elem in elemList: elemType = elem.Type if elemType in ( ElementTypeEnum.kTri3, ElementTypeEnum.kQuad4 ) and existLinearShellElements is False: existLinearShellElements = True elif elemType in ( ElementTypeEnum.kTri6, ElementTypeEnum.kQuad8 ) and existQuadraticShellElements is False: existQuadraticShellElements = True else: pass elif geoBody.BodyType.ToString() == "GeoBodySolid": for elem in elemList: elemType = elem.Type if elemType in ( ElementTypeEnum.kTet4, ElementTypeEnum.kHex8 ) and existLinearSolidElements is False: existLinearSolidElements = True elif elemType in ( ElementTypeEnum.kTet10, ElementTypeEnum.kHex20 ) and existQuadraticSolidElements is False: existQuadraticSolidElements = True else: pass else: pass return [existLinearBeamElements , existQuadraticBeamElements, existLinearShellElements , existQuadraticShellElements , existLinearSolidElements , existQuadraticSolidElements]
