Take screenshot of model in Mechanical
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 900
The following function can be used:
def TakeScreenshot(args): ''' Take screenshot of active object and save it to imagePath.png Note: this function needs to be called in another thread through ExtAPI.Application.InvokeUIThread(TakeScreenshot, [imagePath]) ''' try: imagePath = args[0] setting2d = Ansys.Mechanical.Graphics.GraphicsImageExportSettings() setting2d.Resolution = GraphicsResolutionType.HighResolution setting2d.Width = 838 setting2d.Height = 392 setting2d.Background = GraphicsBackgroundType.White setting2d.CurrentGraphicsDisplay = False totalPath = os.path.join(imagePath) + '.png' ExtAPI.Graphics.ExportImage(totalPath, GraphicsImageExportFormat.PNG, setting2d) except: ExtAPI.Log.WriteMessage("Error : Could not take screenshot")
2 -
Below is a suggested solution to get images of various items. The script will plot to file any selected tree item.
# Script: my_directory = ExtAPI.UserInterface.UIRenderer.ShowFolderOpenDialog() plotItems = ExtAPI.DataModel.Tree.ActiveObjects def slashRemover(n): """ removes / from geometry names """ if '\' in n: n = n.replace('\','_') return n for item in plotItems: item.Activate() saveName = item.Name saveName = slashRemover(saveName) saveCat = item.Parent.Name try: saveCat = item.Parent.Parent.Name except: pass saveNameCat = my_directory + '\' + saveCat + '_' + saveName + '.png' print(saveNameCat) ExtAPI.Graphics.ExportScreenToImage(saveNameCat)
2
