Path results vs time (Graphic control)
Erik Kostson
edited August 2024 in Structures
How can we get the tabular data (without using undocumented and supported commands) when the Graphics Control is set to time (not S).
  • Erik Kostson
    edited August 2024
    One way is to loop over the times and get the max/min/average values and save them in a file.
    model=ExtAPI.DataModel.Project.Model # refer to Model
    analysis = model.Analyses[0]
    solution = analysis.Solution
    ns=DataModel.GetObjectsByName('Selection')[0] # change as needed
    path = DataModel.GetObjectsByName('Path')[0] # change as needed
    res=solution.AddUserDefinedResult()
    res.ScopingMethod=GeometryDefineByType.Path
    res.Location=ns
    res.Location=path
    res.Expression='UZ'
    res.EvaluateAllResults()
    res.GraphControlsXAxis = GraphControlsXAxis.Time
    f1=open("D:\\testexppath.txt","w") #open file in user directory change as needed
    for t in time_steps:
        with Transaction():
            res.DisplayTime=Quantity(float(t), "sec")
            max=res.Maximum
            min=res.Minimum
            ave=res.Average
            f1.write(str(t) + " , " + str(max) +","+ " , " + str(min) + "\n")
    f1.close()
    another perhaps faster way is below (can be easily modified to save to a file - see last script):
    myr=ExtAPI.DataModel.GetObjectsByName("User Defined Result") # name of results to activate
    Tree.Activate(myr)
    paneTabular=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData)
    control = paneTabular.ControlUnknown
    for col in range(1,control.ColumnsCount+1):
        for row in range(1,control.RowsCount+1):
            cellText= control.cell(row ,col ).Text
            if cellText!=None:
                print cellText
    and saving to file:
    Tree.Activate(myr)
    f1=open("D:\\testexppath2.txt","w") #open file in user directory change as needed
            t= control.cell(row ,2).Text
            min= control.cell(row ,3).Text
            max= control.cell(row ,4).Text
            ave= control.cell(row ,5).Text
            f1.write(str(t) + " , " + str(max) + " , " + " , " + str(min) + " , "+str(ave) + "\n")
    f1.close()
