How to make a plot of S11 stresses (fibre-direction) vs z coordinate for named selections?
Javier Vique
Javier Vique Member, Employee Posts: 93
edited August 2024 in Structures
The scenario is a composite model made by solids where user wants to grab S11 stresses of a specific ply, selected by named selections. These elemental named selections are previously created by Worksheet in Mechanical.
  • Javier Vique
    edited August 2024
    With mech-dpf, we can easily grab this data. Data can be output in a csv file, or with the beta functionality of C-python included in Mechanical can be also directly plot in Mechanical.
    Let's assume that we've got the list of named selections in a list called 'ns' and we apply an offset of 135.55mm to the z coordinate of the elements, so z=0 is at the bottom of our model.
    It is also recommended to have a look at this post from our forum.
    import mech_dpf
    mech_dpf.setExtAPI(ExtAPI)
    analysis = Model.Analyses[0]
    WorkDir = analysis.WorkingDir
    model = dpf.Model(analysis.ResultFileName)
    mesh = model.Mesh
    ns = ['PLYA_NS', 'PLYB_NS', 'PLYC_NS', 'PLYD_NS', 'PLYE_NS']
    # Get elements centroids
    op_cent = dpf.operators.result.element_centroids()
    op_cent.inputs.data_sources.Connect(dataSource)
    op_cent.inputs.bool_rotate_to_global.Connect(True)
    cent_field = op_cent.outputs.fields_container.GetData()[0]
    # Apply offset to z coordinate
    op_add = dpf.operators.math.add_constant()
    op_add.inputs.field.Connect(cent_field)
    op_add.inputs.ponderation.Connect(135.55)
    cent_field_d = op_add.outputs.field.GetData()
    # Get results for each ply
    for ply in ns:
        ply_mesh_region = model.GetNamedSelection(ply)
        op_rscope = dpf.operators.scoping.rescope()
        op_rscope.inputs.fields.Connect(cent_field_d)
        op_rscope.inputs.mesh_scoping.Connect(ply_mesh_region)
        cent_ply = op_rscope.outputs.fields.GetDataT2()
        op_z = dpf.operators.logic.component_selector()
        op_z.inputs.field.Connect(cent_ply)
        op_z.inputs.component_number.Connect(2)
        centZ_ply = op_z.outputs.field.GetData()
        op_s11 = dpf.operators.result.stress_X()
        op_s11.inputs.mesh_scoping.Connect(ply_mesh_region)
        op_s11.inputs.requested_location.Connect(dpf.locations.elemental_nodal)
        op_s11.inputs.data_sources.Connect(dataSource)
        op_s11.inputs.bool_rotate_to_global.Connect(False)
        s11 = op_s11.outputs.fields_container.GetData()[0]
        z = []
        s11_max = []
        for Elem in s11.ScopingIds:
            z.append(centZ_ply.GetEntityDataById(Elem)[0])
            s11_max.append(max(s11.GetEntityDataById(Elem),key=abs))
        data_sorted_byZ = sorted(zip(z,s11_max), key=lambda x: x[0])
        file = ply[:-3] + '.csv'
        file_path = os.path.join(WorkDir,file)
        with open(file_path,'w') as f:
            [f.write('%.3f,%.3f\n' % (zi,s11i)) for zi,s11i in data_sorted_byZ]
    model.ReleaseStreams()
