Correct way to extract Harmonic Response Frequency Results
mgoldgruber
Member, Employee Posts: 3
When extracting Frequency Response Results with PyMechanical the order of operations performed on the real and imaginary parts to calculate the amplitude is important. Analogous to vector operations, accumulating the real and imaginary components separately, before combining them to calculate the amplitude is mandatory.
This might sound obvious, but doing the amplitude calculation first and then the accumulation and averaging, is a trap that is easy to fall into.
def after_post(this, solution):# Do not edit this line """ Called after post processing. Keyword Arguments : this -- the datamodel object instance of the python code object you are currently editing in the tree solution -- Solution """ import os import wbjn import Ans.DataProcessing as dpf # RESULTS FILE NAME myResName = 'Freq_amp' dpn = wbjn.ExecuteCommand(ExtAPI,"returnValue(a+Parameters.GetActiveDesignPoint().Name)",a="DP") projectDir = wbjn.ExecuteCommand(ExtAPI,"returnValue(GetUserFilesDirectory())") filePath = os.path.join(projectDir,dpn + '_' + myResName + '.txt') if os.path.isfile(filePath): os.remove(filePath) #Remove old file if exists # DEFINE DATASOURCE --> .RST/.RTH dataSource = dpf.DataSources(solution.Parent.ResultFileName) # Use in Tree for solution # GET TIMESTEPS OR FREQUENCIES freqlist = dpf.operators.metadata.time_freq_provider(data_sources=dataSource).outputs.gettime_freq_support().TimeFreqs.Data # GET RESULT FIELD CONTAINER (e.g. Acceleration in Z direction) ACC_Z = dpf.operators.result.acceleration_Z(time_scoping=freqlist, data_sources=dataSource).outputs.getfields_container() # OPERATE ON RESULT # 1. Calculate Accumulated results component-wise (real, imaginary) over all nodes accum = dpf.operators.math.accumulate_fc(fields_container=ACC_Z) # 2. Calculate Average over all Nodes avg = dpf.operators.math.scale_fc(fields_container=accum, ponderation=1.0/ACC_Z[0].ElementaryDataCount) # 3. Calculate Amplitude of Real/Imaginary Data amp = dpf.operators.math.amplitude_fc(fields_container=avg) #WRITE TO FILE with open(filePath,'w') as f: # write column headers f.write( 'Frequency, Amplitude') f.write('\n') for i, freq in enumerate(freqlist): f.write( str(freq) + ', ' + str(amp.outputs.getfields_container()[i].Data[0]) ) f.write('\n') pass
