Plot stress data on surface coating elements
Pernelle Marone-Hitz
Pernelle Marone-Hitz Member, Moderator, Employee Posts: 900
How can I use DPF to retrieve stress data on surface coating elements and plot those results in Mechanical ?
    First, it is important to understand that there are two options to create surface coating elements in Mechanical.
    • Option 1: Define a surface coating object at the geometry level
    • Option 2: Add a Mesh Edit / Pull / Surface coating object
      Once generated, this will create a new surface body in the geometry:
    To post-process the results through the Mechanical UI, the procedure will be different based on how these surface coating elements were generated:
    • Option 1: Add a result and use the geometry scoping
    • Option 2: Add a result but this time set scoping method to "Surface coating"
    As the surface coating objects are created differently, the way to retrieve the result data through DPF will slightly differ:
    • Option 1: we can use GetObjectsByType() method to grab the surface coating object
    • Option 2: we can use GetObjectsByName() method to grab the body by its name, or any similar option, but surface coating bodies created through this option are not recognized as surface coatings but as standard bodies.
    The rest of the method is very similar:
    • use DPF to retrieve stress results
    • use SolverData API to restrict the scoping to surface coating elements
    • create a mesh for the surface coating elements only
    • plot the results with the restricted scoping on the restricted mesh.
    edited August 2024
    The main Python Result function define_dpf_workflow() will slighlty differ for the two options:
    • Option 1: surface coating created at geometry level
        # import DPF and define data sources
        import mech_dpf
        mech_dpf.setExtAPI(ExtAPI)
        model = dpf.Model(dataSource)
        # retrieve entire mesh
        whole_mesh = model.Mesh
        # retrieve nodal Von Mises stress
        seqv = dpf.operators.result.stress_von_mises()
        seqv.inputs.data_sources.Connect(dataSource)
        seqv.inputs.requested_location.Connect(dpf.locations.nodal)
        # identify surface coating elements
        surface_coating = ExtAPI.DataModel.GetObjectsByType(Ansys.ACT.Automation.Mechanical.SurfaceCoating)[0]
        solver_data = analysis.Solution.SolverData
        coating_data = solver_data.GetObjectData(surface_coating)
        matid_sc_1 = coating_data.MaterialId.ToString()
        surface_coating_elements = solver_data.ElementIdsByMaterialId(matid_sc_1)
        # define mesh scoping for surface coating elements
        mesh_scoping=dpf.Scoping()
        mesh_scoping.Location = dpf.locations.elemental
        mesh_scoping.Ids=surface_coating_elements
        # restrict stress results to surface coating elements
        seqv.inputs.mesh_scoping.Connect(mesh_scoping)
        # get mesh for surface coating elements only
        mesh_from_scoping = dpf.operators.mesh.from_scoping()
        mesh_from_scoping.inputs.scoping.Connect(mesh_scoping)
        mesh_from_scoping.inputs.mesh.Connect(whole_mesh)
        my_mesh = mesh_from_scoping.outputs.getmesh()
        dpf_workflow = dpf.Workflow()
        dpf_workflow.Add(seqv)
        # plot on restricted mesh
        dpf_workflow.SetOutputMesh(my_mesh)
        dpf_workflow.SetOutputContour(seqv)
    edited August 2024
    • Option 2: surface coating created through mesh edit / pull
        import mech_dpf
        surface_coating = ExtAPI.DataModel.GetObjectsByName('Surface body from mesh edit pull')[0]
        matid_sc_1 = coating_data.MaterialIds[0].ToString()
    In both cases we are able to get the same results as in Mechanical:
    • Option 1:
    • Option 2:
