Error importing PyPrimeMesh library
CoolHarrison
CoolHarrison Member Posts: 18
10 Comments
In this code,
import ansys.meshing.prime as prime with prime.launch_prime() as prime_client: ...
I am getting this error:
Exception has occurred: FileNotFoundError No valid Ansys Prime Server found to launch. File "C:\Users\forha\OneDrive\Documents\GitHub\F1car-wAI\fluentTest.py", line 207, in <module> with prime.launch_prime() as prime_client: ^^^^^^^^^^^^^^^^^^^^ FileNotFoundError: No valid Ansys Prime Server found to launch.
I'm not sure what it really means, or how to get the Ansys Prime Server. Thanks in advance for the help.
Best Answers
  • CoolHarrison
    10 Comments
    Hello, I did some more research and I think its because PyPrimeMesh isn't with the student version, which is what I have.
  • CoolHarrison
    10 Comments
    Hello, I talked with customer service about it and it appears that pyprimemesh doesn't come in the student version, so i think that's the answer. Thanks for the help nonetheless.
  • Alan Varghese
    Alan Varghese Member, Employee Posts: 4
    Second Anniversary First Comment Ansys Employee Solution Developer Community of Practice Member
    Hi ,
    This error could arise due to to reasons ,
    1. Client and Server version mismatch
    Can you check the client and server versions are matching , you can refer to the following document
    https://prime.docs.pyansys.com/version/stable/getting_started/index.html
    1. Ansys PyPrimeMesh server executables missing
    Within the Ansys unified installed directory , there should be folder namely meshing . This can be located as follow
    Assuming you have 2024 R2 installed , the following path should exist
    C:\Program Files\ANSYS Inc\v242\meshing
