How to plot Contact Pressure (Elemental Averaged) using Python Result in Mechanical?
Rohith Patchigolla
Member, Moderator, Employee Posts: 249
The below code can be pasted in a Python Result object (create a new Python Result object in Mechanical --> replace the already existing script with the below script) and this script takes the name of a Contact Object in Mechanical (needs to be unique) as an input to get the contact elements. You can use different methods here to extract multiple or all contact elements at once as well.
def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) dataSource = dpf.DataSources(analysis.ResultFileName) model = dpf.Model(dataSource) whole_mesh = model.Mesh # identify Contact Elements from a Contact Object based on Name contObj = ExtAPI.DataModel.GetObjectsByName("Contact Region - PythonResult")[0] solver_data = analysis.Solution.SolverData contData = solver_data.GetObjectData(contObj) mat_cont_1 = contData.SourceId.ToString() contObj_elements = solver_data.ElementIdsByMaterialId(mat_cont_1) mesh_scoping=dpf.Scoping() mesh_scoping.Location = dpf.locations.elemental mesh_scoping.Ids=contObj_elements mesh_from_scoping = dpf.operators.mesh.from_scoping() mesh_from_scoping.inputs.scoping.Connect(mesh_scoping) mesh_from_scoping.inputs.mesh.Connect(whole_mesh) my_mesh = mesh_from_scoping.outputs.getmesh() cont_pres_op = dpf.operators.result.contact_pressure(data_sources=dataSource,mesh_scoping=mesh_from_scoping,requested_location="Elemental") dpf_workflow = dpf.Workflow() dpf_workflow.Add(cont_pres_op) dpf_workflow.SetOutputMesh(my_mesh) dpf_workflow.SetOutputContour(cont_pres_op) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
And the below script is for plotting unaveraged contact pressure results using Python Result object.
def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) dataSource = dpf.DataSources(analysis.ResultFileName) model = dpf.Model(dataSource) whole_mesh = model.Mesh # identify Contact Elements from a Contact Object based on Name contObj = ExtAPI.DataModel.GetObjectsByName("Contact Region - PythonResult")[0] solver_data = analysis.Solution.SolverData contData = solver_data.GetObjectData(contObj) mat_cont = contData.SourceId.ToString() mat_targ = contData.TargetId.ToString() contObj_nodes = solver_data.ElementIdsByMaterialId(mat_cont) mesh_scoping=dpf.Scoping() mesh_scoping.Location = dpf.locations.elemental_nodal mesh_scoping.Ids=contObj_nodes mesh_from_scoping = dpf.operators.mesh.from_scoping() mesh_from_scoping.inputs.scoping.Connect(mesh_scoping) mesh_from_scoping.inputs.mesh.Connect(whole_mesh) my_mesh = mesh_from_scoping.outputs.getmesh() cont_pres_op = dpf.operators.result.contact_pressure(data_sources=dataSource,mesh_scoping=mesh_from_scoping) dpf_workflow = dpf.Workflow() dpf_workflow.Add(cont_pres_op) dpf_workflow.SetOutputMesh(my_mesh) dpf_workflow.SetOutputContour(cont_pres_op) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
