Import displacement over time from Excel through Mechanical scripting
Martin Husek
Member, Employee Posts: 3
Using ACT, how can I import displacement values over time from an Excel spreadsheet to tabular data?
You can use the following code:
1. import clr 2. clr.AddReferenceByName('Microsoft.Office.Interop.Excel') 3. from Microsoft.Office.Interop import Excel 4. 5. # Files 6. filePath = r'D:\Data.xlsx' 7. 8. # Data in Excel 9. worksheetName = 'Data' 10. rows = [2, 52] # without header 11. columns = ['A','B'] # e.g. time vs displacement 12. 13. # Import displacement over time from the Excel spreadsheet 14. excel = Excel.ApplicationClass() 15. excel.Visible = False 16. excel.ScreenUpdating = False 17. excel.DisplayAlerts = False 18. excel.AskToUpdateLinks = False 19. 20. workbook = excel.Workbooks.Open(filePath) 21. worksheet = workbook.worksheets(worksheetName) 22. 23. values = [] 24. ranges = [c + str(rows[0]) + ':' + c + str(rows[-1]) for c in columns] 25. for range in ranges: 26. temp = [] 27. column = worksheet.Range[range] 28. for cell, row in zip(column, column.Rows): 29. temp.append(cell.Value2) 30. values.append(temp) 31. 32. excel.Application.Quit() 33. excel.Quit() 34. 35. # Create a displacement boundary condition 36. Analysis = ExtAPI.DataModel.Project.Model.Analyses[0] 37. Displacement = Analysis.AddDisplacement() 38. Displacement.DefineBy = LoadDefineBy.NormalToOrTangential 39. 40. # Push data from the Excel spreadsheet to tabular data 41. Displacement.Distance.Inputs[0].DiscreteValues = [Quantity('{}[s]'.format(t)) for t in values[0]] 42. Displacement.Distance.Output.DiscreteValues = [Quantity('{}[mm]'.format(d)) for d in values[1]]
1
