How to export Min or Max temperature time history (same as Tabular Data) at multiple named selections as a csv from Mechanical thermal analysis?
Below script exports the Max or Min time history as csv for multiple named selections (say T1 and T2) in the analysis solver directory.
import mech_dpf import Ans.DataProcessing as dpf import csv import os import time startTime = time.time() mech_dpf.setExtAPI(ExtAPI) analysis = DataModel.AnalysisList[0] # Specify the file name for Max and Min data filenameMax = "output_max.csv" filepath = analysis.WorkingDir fullpathMax = os.path.join(filepath,filenameMax) filenameMin = "output_min.csv" filepath = analysis.WorkingDir fullpathMin = os.path.join(filepath,filenameMin) dataSource = dpf.DataSources(analysis.ResultFileName) time_freq_support = dpf.operators.metadata.time_freq_provider(data_sources = dataSource) n_sets = time_freq_support.outputs.time_freq_support.GetData().NumberSets timeScop = dpf.Scoping() timeScop.Ids = range(1, n_sets + 1) NamedSelNames = ['T1', 'T2', 'T3', 'T4', 'T5', 'T6', 'T7', 'T8', 'T9', 'T10', 'T11', 'T12', 'T13', 'T14', 'T15', 'T16', 'T17', 'T18', 'T19', 'T20', 'T21', 'T22', 'T23', 'T24', 'T25', 'T26', 'T27', 'T28', 'T29', 'T30', 'T31', 'T32', 'T33', 'T34'] fullDataMax = [] fullDataMin = [] for nsName in NamedSelNames: ns_op = dpf.operators.scoping.on_named_selection(data_sources = dataSource, requested_location = 'Nodal', named_selection_name = nsName) temp_op = dpf.operators.result.temperature(data_sources = dataSource, time_scoping = timeScop, mesh_scoping = ns_op.outputs.mesh_scoping) temp_fc = temp_op.outputs.fields_container.GetData() minTemps = [] maxTemps = [] min_max_fc_op = dpf.operators.min_max.min_max_fc() # operator instantiation min_max_fc_op.inputs.fields_container.Connect(temp_fc) minTemps = min_max_fc_op.outputs.field_min.GetData().Data maxTemps = min_max_fc_op.outputs.field_max.GetData().Data fullDataMax.append(maxTemps) fullDataMin.append(minTemps) fullDataMax = list(zip(*fullDataMax)) fullDataMin = list(zip(*fullDataMin)) # Writing to csv file with open(fullpathMax, mode='w') as file: writer = csv.writer(file, lineterminator='\n') writer.writerow(NamedSelNames) for row in fullDataMax: writer.writerow(row) with open(fullpathMin, mode='w') as file: writer = csv.writer(file, lineterminator='\n') writer.writerow(NamedSelNames) for row in fullDataMin: writer.writerow(row) endTime = time.time() TotalTime = endTime - startTime ExtAPI.Log.WriteMessage("Total Time taken for export is " + str(TotalTime) + " Sec")
