How to create a post object in Mechanical with ACT
I would like to create an object in the solution folder.
This object should write an APDL code in the ds.dat file after the solve.
I create with succes this kind of object in preprocessing :
    <load name="[Spectral] CQC" version="1" caption="[Spectral] CQC" icon="seisme" isload="true" color="#ff3300">
      <callbacks>
        <!-- This function is going to add APDL commands to the solver input (ds.dat) file in run time -->
        <getsolvecommands>writeCQCLoad</getsolvecommands>
      </callbacks>
      <!-- Expose 4 user inputs to collect for the APDL command -->
      <property name="CQC"  caption= "Significant parameter" control="float" default="0.001"/>
    </load>
I try do do the same in the post, but it dosn't work.
Is there any idea or example ?
Thanks,
Regards,
Jean
    Pernelle Marone-Hitz Member, Moderator, Employee Posts: 871
    100 Answers 500 Comments 250 Likes First Anniversary
    Another option is to use the callback, and define where the command should be added through the "location" parameter:
  • Jean
    Jean Member Posts: 29
    10 Comments 5 Likes First Anniversary Name Dropper
    I found a solution :
    <load name="[Spectral] CQC" version="1" caption="[Spectral] CQC" icon="damping" isload="true" color="#ff3300" contextual="False">
    <callbacks>
    </callbacks>
    </load>
  • Jean
    I made a mistake in my previous post.
    The correct code should replace :
    with :
    <getpostcommands>writeCQCLoad</getpostcommands>
