PyPrimeMesh CAD import failed
I am attempting to use PyPrimeMesh for the first time and I am getting errors loading CAD files. I am using the ANSYS Python Manager to setup environment. Using Python 3.10.11 with the 2024.2.4 PyAnsys metapackage. Windows 10 with 2024R2 installed.
import ansys.meshing.prime as prime
with prime.launch_prime() as prime_client:
    model = prime_client.model
    # Download and read an example Spaceclaim file
    mixing_elbow = prime.examples.download_elbow_scdoc()
    params = prime.ImportCadParams(
        model=model, cad_reader_route=prime.CadReaderRoute.SPACECLAIM
    prime.FileIO(model).import_cad(file_name=mixing_elbow, params=params)
Generates error:
PrimeRuntimeError                         Traceback (most recent call last)
Cell In[2], line 9
      5 mixing_elbow = prime.examples.download_elbow_scdoc()
      6 params = prime.ImportCadParams(
      7     model=model, cad_reader_route=prime.CadReaderRoute.SPACECLAIM
      8 )
----> 9 prime.FileIO(model).import_cad(file_name=mixing_elbow, params=params)
File ~\.ansys_python_venvs\3_10_11_pyensys_mgr\lib\site-packages\ansys\meshing\prime\core\fileio.py:586, in FileIO.import_cad(self, file_name, params)
    543 r"""Import a CAD file from disk.
    544
    545 Supported CAD file formats on Windows are:
    583
    584 """
    585 with utils.file_read_context(self._model, file_name) as temp_file_name:
--> 586     import_result = super().import_cad(temp_file_name, params)
    587     if import_result.error_code == ErrorCode.NOERROR:
    588         self._model._sync_up_model()
File ~\.ansys_python_venvs\3_10_11_pyensys_mgr\lib\site-packages\ansys\meshing\prime\autogen\fileio.py:692, in FileIO.import_cad(self, file_name, import_cad_params)
    690 command_name = "PrimeMesh::FileIO/ImportCAD"
    691 self._model._print_logs_before_command("import_cad", args)
--> 692 result = self._comm.serve(self._model, command_name, self._object_id, args=args)
    693 self._model._print_logs_after_command("import_cad", ImportCadResults(model = self._model, json_data = result))
    694 return ImportCadResults(model = self._model, json_data = result)
File ~\.ansys_python_venvs\3_10_11_pyensys_mgr\lib\site-packages\ansys\meshing\prime\internals\error_handling.py:577, in error_code_handler.<locals>.decorator_error_code.<locals>.wrapper_error_code(*args, **kwargs)
    571     if error_code > 0:
    572         error_location_msg = (
    573             f'\nError Locations: {error_locations}'
    574             if len(error_locations) > 0
    575             else f''
    576         )
--> 577         raise PrimeRuntimeError(
    578             prime_error_messages.get(
    579                 ErrorCode(error_code), f'Unrecogonized error code {error_code}'
    580             )
    581             + error_location_msg,
    582             ErrorCode(error_code),
    583             error_locations,
    584         )
    586 prime_warnings = []
    587 single_warning = result.get('warningCode', None)
PrimeRuntimeError: CAD import failed.****
  • cvaero
    cvaero Member Posts: 10
    pip freeze output:
    about-time==4.2.1
    aiohappyeyeballs==2.4.0
    aiohttp==3.10.5
    aiosignal==1.3.1
    alive-progress==3.1.5
    annotated-types==0.7.0
    ansys-acp-core==0.1b2
    ansys-additive-core==0.18.1
    ansys-additive-widgets==0.2.1
    ansys-api-acp==0.1.0.dev9
    ansys-api-additive==1.7.2
    ansys-api-dbu==0.3.4
    ansys-api-dyna==0.3.6
    ansys-api-edb==1.0.6
    ansys-api-fluent==0.3.27
    ansys-api-geometry==0.4.6
    ansys-api-mapdl==0.5.2
    ansys-api-mechanical==0.1.2
    ansys-api-meshing-prime==0.1.3
    ansys-api-modelcenter==0.3.1
    ansys-api-platform-instancemanagement==1.1.0
    ansys-api-pyensight==0.4.1
    ansys-api-sherlock==0.1.27
    ansys-api-systemcoupling==0.1.0
    ansys-api-tools-filetransfer==0.1.0
    ansys-api-workbench==0.2.0
    ansys-conceptev-core==0.1.4
    ansys-dpf-composites==0.5.0
    ansys-dpf-core==0.12.2
    ansys-dpf-post==0.8.0
    ansys-dyna-core==0.4.15
    ansys-dynamicreporting-core==0.6.0
    ansys-edb-core==0.1.6
    ansys-engineeringworkflow-api==0.1.0
    ansys-fluent-core==0.22.0
    ansys-geometry-core==0.6.6
    ansys-grantami-bomanalytics==2.1.1
    ansys-grantami-bomanalytics-openapi==3.0.0
    ansys-grantami-jobqueue==1.0.1
    ansys-grantami-recordlists==1.2.1
    ansys-grantami-serverapi-openapi==3.0.0
    ansys-hps-client==0.8.0
    ansys-mapdl-core==0.68.4
    ansys-mapdl-reader==0.54.0
    ansys-math-core==0.1.5
    ansys-mechanical-core==0.11.5
    ansys-mechanical-env==0.1.7
    ansys-meshing-prime==0.6.2
    ansys-modelcenter-workflow==0.1.1
    ansys-motorcad-core==0.5.5
    ansys-openapi-common==2.1.1
    ansys-optislang-core==0.8.0
    ansys-platform-instancemanagement==1.1.2
    ansys-pyensight-core==0.8.8
    ansys-pythonnet==3.1.0rc3
    ansys-rocky-core==0.2.0
    ansys-seascape==0.2.0
    ansys-sherlock-core==0.6.0
    ansys-simai-core==0.2.2
    ansys-sound-core==0.1.3
    ansys-systemcoupling-core==0.6
    ansys-tools-filetransfer==0.1.0
    ansys-tools-local-product-launcher==0.1.0
    ansys-tools-path==0.6.0
    ansys-tools-visualization-interface==0.4.1
    ansys-turbogrid-api==0.4.3
    ansys-turbogrid-core==0.4.1
    ansys-units==0.3.2
    ansys-workbench-core==0.6.0
    anyio==4.4.0
    appdirs==1.4.4
    argon2-cffi==23.1.0
    argon2-cffi-bindings==21.2.0
    arrow==1.3.0
    asgiref==3.8.1
    asttokens==2.4.1
    async-lru==2.0.4
    async-timeout==4.0.3
    attrs==24.2.0
    babel==2.16.0
    backoff==2.2.1
    backports.entry-points-selectable==1.3.0
    backports.tarfile==1.2.0
    bcrypt==4.2.0
    beartype==0.18.5
    beautifulsoup4==4.12.3
    bleach==6.1.0
    bokeh==3.4.3
    build==1.2.1
    cachetools==5.5.0
    certifi==2024.8.30
    cffi==1.17.0
    charset-normalizer==3.3.2
    click==8.1.7
    clr-loader==0.2.6
    colorama==0.4.6
    comm==0.2.2
    contourpy==1.3.0
    cryptography==43.0.1
    cycler==0.12.1
    debugpy==1.8.5
    decorator==5.1.1
    defusedxml==0.7.1
    Deprecated==1.2.14
    dill==0.3.8
    Django==5.1.1
    docker==7.1.0
    docutils==0.21.2
    elementpath==4.4.0
    exceptiongroup==1.2.2
    executing==2.1.0
    fabric==3.2.2
    fastjsonschema==2.20.0
    filelock==3.15.4
    flexcache==0.3
    flexparser==0.3.1
    fonttools==4.53.1
    fpdf2==2.7.9
    fqdn==1.5.1
    frozenlist==1.4.1
    geomdl==5.3.1
    google-api-core==2.19.2
    google-api-python-client==2.143.0
    google-auth==2.34.0
    google-auth-httplib2==0.2.0
    googleapis-common-protos==1.65.0
    grapheme==0.6.0
    grpcio==1.66.1
    grpcio-health-checking==1.48.2
    grpcio-status==1.48.2
    h11==0.14.0
    httpcore==1.0.5
    httplib2==0.22.0
    httpx==0.26.0
    idna==3.8
    importlib_metadata==8.4.0
    invoke==2.2.0
    ipykernel==6.29.5
    ipython==8.27.0
    ipywidgets==8.1.5
    isoduration==20.11.0
    jaraco.classes==3.4.0
    jaraco.context==6.0.1
    jaraco.functools==4.0.2
    jedi==0.19.1
    Jinja2==3.1.4
    joblib==1.4.2
    json5==0.9.25
    jsonpointer==3.0.0
    jsonschema==4.23.0
    jsonschema-specifications==2023.12.1
    jupyter==1.1.1
    jupyter-console==6.6.3
    jupyter-events==0.10.0
    jupyter-lsp==2.2.5
    jupyter_client==8.6.2
    jupyter_core==5.7.2
    jupyter_server==2.14.2
    jupyter_server_terminals==0.5.3
    jupyterlab==4.2.5
    jupyterlab_pygments==0.3.0
    jupyterlab_server==2.27.3
    jupyterlab_widgets==3.0.13
    keyring==25.3.0
    kiwisolver==1.4.6
    linkify-it-py==2.0.3
    lxml==5.3.0
    Markdown==3.7
    markdown-it-py==3.0.0
    MarkupSafe==2.1.5
    marshmallow==3.22.0
    marshmallow-oneofschema==3.1.1
    matplotlib==3.9.2
    matplotlib-inline==0.1.7
    mdit-py-plugins==0.4.1
    mdurl==0.1.2
    mistune==3.0.2
    more-itertools==10.4.0
    msgpack==1.0.8
    multidict==6.0.5
    nbclient==0.10.0
    nbconvert==7.16.4
    nbformat==5.10.4
    nest-asyncio==1.6.0
    nh3==0.2.18
    nltk==3.9.1
    notebook==7.2.2
    notebook_shim==0.2.4
    numpy==1.26.4
    overrides==7.7.0
    packaging==24.1
    pandas==2.2.2
    pandocfilters==1.5.1
    panel==1.4.4
    param==2.1.1
    paramiko==3.4.1
    parso==0.8.4
    pillow==10.4.0
    Pint==0.24.3
    pkginfo==1.10.0
    platformdirs==4.2.2
    plumbum==1.8.3
    pooch==1.8.2
    prometheus_client==0.20.0
    prompt_toolkit==3.0.47
    proto-plus==1.24.0
    protobuf==3.20.3
    psutil==6.0.0
    pure_eval==0.2.3
    pyaedt==0.9.11
    pyansys==2024.2.4
    pyansys-tools-variableinterop==0.1.1
    pyansys-tools-versioning==0.6.0
    pyasn1==0.6.0
    pyasn1_modules==0.4.0
    pycparser==2.22
    pydantic==2.8.2
    pydantic_core==2.20.1
    pyedb==0.23.0
    Pygments==2.18.0
    pygranta==2024.2.0
    pyiges==0.3.1
    PyJWT==2.9.0
    PyNaCl==1.5.0
    pyparsing==3.1.4
    pypiwin32==223
    pypng==0.20220715.0
    pyproject_hooks==1.1.0
    Pyro5==5.15
    pyspnego==0.11.1
    python-dateutil==2.9.0.post0
    python-dotenv==1.0.1
    python-json-logger==2.0.7
    pytomlpp==1.0.13
    pytwin==0.7.0
    pytz==2024.1
    pyvista==0.43.4
    pyviz_comms==3.0.3
    pywin32==306
    pywin32-ctypes==0.2.3
    pywinpty==2.0.13
    PyYAML==6.0.2
    pyzmq==26.2.0
    readme_renderer==44.0
    referencing==0.35.1
    regex==2024.7.24
    requests==2.32.3
    requests-negotiate-sspi==0.5.2
    requests-toolbelt==1.0.0
    requests_ntlm==1.3.0
    rfc3339-validator==0.1.4
    rfc3986==2.0.0
    rfc3986-validator==0.1.1
    rich==13.8.0
    rpds-py==0.20.0
    rpyc==6.0.0
    rsa==4.9
    Rtree==1.3.0
    scikit-rf==1.3.0
    scipy==1.14.1
    scooby==0.10.0
    semver==3.0.2
    Send2Trash==1.8.3
    serpent==1.41
    six==1.16.0
    sniffio==1.3.1
    soupsieve==2.6
    sqlparse==0.5.1
    sseclient-py==1.8.0
    sspilib==0.1.0
    stack-data==0.6.3
    tabulate==0.9.0
    terminado==0.18.1
    tinycss2==1.3.0
    toml==0.10.2
    tomli==2.0.1
    tornado==6.4.1
    tqdm==4.66.5
    traitlets==5.14.3
    trame==3.6.3
    trame-client==3.2.5
    trame-server==3.1.2
    trame-vtk==2.8.10
    trame-vuetify==2.7.1
    twine==5.1.1
    types-python-dateutil==2.9.0.20240821
    typing_extensions==4.12.2
    tzdata==2024.1
    uc-micro-py==1.0.3
    uri-template==1.3.0
    uritemplate==4.1.1
    urllib3==1.26.20
    vtk==9.3.1
    wakepy==0.9.1
    wcwidth==0.2.13
    webcolors==24.8.0
    webencodings==0.5.1
    websocket-client==1.8.0
    websockets==12.0
    widgetsnbextension==4.0.13
    WMI==1.5.1
    wrapt==1.16.0
    wslink==2.1.2
    xmlschema==2.5.1
    xyzservices==2024.9.0
    yarl==1.9.7
    zipp==3.20.1
  • Alan Varghese
    Alan Varghese Member, Employee Posts: 4
    Second Anniversary First Comment Ansys Employee Solution Developer Community of Practice Member
    Hi ,
    There is a similar issue observed while launching a console from Ansys Python Manager , Please do find the details below
    https://github.com/ansys/python-installer-qt-gui/issues/343
    The recommended course of action would be to install the latest version of Ansys Python Manager, the fix is available with Ansys Python Manager version v0.3.8
