How to parametrize User Defined Membrane Offset in Mechanical?
Rohith Patchigolla
I would like to parametrize "Membrane Offset" highlighted below. This is not natively possible.
  • Rohith Patchigolla
    One can use Python Code object inserted under the Surface body to parametrize the Membrane offset value.
    Here are the steps:
    1. RMB on the Surface Body --> Insert --> Python Code
    2. Change the "Target Callback" property to "After Object Changed"
    3. Paste the below script under the "Script" tab (Python code object has two tabs. Script tab to create an automation script, Property Provider tab to create custom properties to input data)
    def after_object_changed(this, object_changed, property_name):# Do not edit this line
        Called after an object is changed.
        Keyword Arguments :
            object_changed -- The object that was changed
            property_name -- The property that was changed
        if object_changed == this:
            surfaceBody = this.Parent
            offsetVal = this.GetCustomPropertyByPath("Properties/Membrane Offset").Value
            unit = surfaceBody.OffsetX.Unit
            surfaceBody.OffsetX = Quantity(offsetVal,unit)
    1. Replace the function "reload_properties" with the below script under "Property Provider" tab. This step is to create a custom property under Python Code object properties, which can be parametrized. We then connect this number to the Offset value in Surface body using Mechanical scripting.
    def reload_props():
        this.PropertyProvider = None
        provider = Provider()
        group = provider.AddGroup("Properties")
        double_prop = group.AddProperty("Membrane Offset", Control.Double)
        # Configure the double property to be parameterizable. As a default the property will be an input parameter.
        # However, by updating the ParameterType property, it can be configured to be a output parameter as well.
        double_prop.CanParameterize = True
        # Connects the provider instance back to the object by setting the PropertyProvider member on this, 'this' being the
        # current instance of the Python Code object.
    1. RMB on Python Code --> Reload. This should show a new property under Python Code called "Membrane Offset". This can also be parametrized like any other Mechanial parameters.
    2. RMB on Python Code --> Connect
    3. Try changing the number here in Python Code properties and verify if its changing the Membrane offset in the Surface body and if you encounter any error messages in Mechanical (if yes, debugging of code is needed)
    4. Also go to WB --> Tools --> Options --> Mechanical --> "Reconnect Python Code Object when Mechanical is launched". This step needs to be done before starting design point studies.
