Wrong calculation result when using imported user module?
I am trying to develop a script to do some fatigue calculations, but I noticed something weird and wanted to investigate further.
I noticed when I use a function from an imported user module, the result is for some reason different than if I run the same function from the module itself.
I have following code which is a part of a module I will import into the main script:
from module_base import * #This will import the Ansys.Mechanical.DataModel.Enums items
import math #another modules you are using in the project
def Initialize(MyExtAPI, MyAnsys):
global ExtAPI; global Ansys
ExtAPI = MyExtAPI; Ansys = MyAnsys
def CalculateFatigueLife_DNV_Test(stress_range, SN_Curve,thickness,SCF=1,ref_thickness=25):
m1=3
log_a1=12.192
m2=5
log_a2=16.32
k=0.05
trans=1000000
log_N=log_a1-m1*math.log10(stress_range*SCF*math.pow(thickness/ref_thickness,k))
N = math.pow(10,log_N)
if(N>trans):
    log_N=log_a2-m2*math.log10(stress_range*SCF*math.pow(thickness/ref_thickness,k))
return N
print(CalculateFatigueLife_DNV_Test(334.7,"C CP",30,1,25))
import math
import Ansys.ACT.Math as math_ACT
import mech_dpf
import sys
CodePath = r"D:\ANSYS Scripts"
if not CodePath in sys.path:
sys.path.append(CodePath)
import FatigueFunctions as FF #module with fatigue calculations functions
reload(FF)
FF.Initialize(ExtAPI, Ansys)
print(FF.CalculateFatigueLife_DNV(334.7,"C CP",30,1,25))
print("Test: "+repr(FF.CalculateFatigueLife_DNV_Test(334.7,"C CP",30,1,25)))
The code above prints: "Test: 41498.544"
I don't understand why when I call the function from the main code I get the different result from running the same function from the imported module. Is this a bug? Did anyone come across this before? My end plan here is to develop a module I can import into other scripts to carry out calculations etc.
Thanks
Running the main script yields the following message
  • ArnoldH
    ArnoldH Member Posts: 7
    Something went wrong with the formatting in my post, I apologise, please see the below for clarity.
    Imported module:
    m1=3
    log_a1=12.192
    m2=5
    log_a2=16.32
    k=0.05
    trans=1000000
    The above produces message: "40379" (and some extra digits
    Main code:
    import math
    import mech_dpf
    import sys
    reload(FF)
    The above produces following message: "Test: 41498" (and again, some extra digits)
  • Landon Mitchell Kanner
    edited September 2024
    The issue is that the thickness and ref_thickness arguments are both being defined as integers, which causes thickness/ref_thickness to evaluate as 1 (an integer) instead of 1.2. I am not sure why we don't see this behavior when running the function directly in Mechanical, but luckily this allowed you to catch the bug.
    A quick fix is to add this line to your function:
        thickness = float(thickness)
    I did a little more digging. The Mechanical scripting environment seems to always return a float from integer division. This is not the default behavior for IronPython 2.7 (which is what Mechanical runs). I suspect that the Mechanical initialization scripts include something like:
    from __future__ import division
    An alternative solution is to add the above line to the top of your FatigueFunctions.py file.
    I have had issues myself with using integers to do math operations and not remembering that they are different from a float. It would be best practice to code your math functions with a float(SomeVal) function to ensure the input values are actually float numbers and not integers when appropriate.
  • ArnoldH
    @Landon Mitchell Kanner , casting thickness as float seems to have solved this issue, The results are now matching the calculations. I will add some comments into the code to remember about this behaviour in the future. Thanks for help.
