Hello, I am now following this instruction (https://developer.ansys.com/blog/script-tip-friday-python-code-object-mechanical) to use "Python Codes" for post-processing. However, I am encountered with the following errors:
failed to create drawable
failed to create drawable X
Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 53 (X_CreatePixmap)
Value in failed request: 0x1e
Serial number of failed request: 30
Current serial number in output stream: 36
Any suggestions to correct it? Thanks a lot!
