How to extract result fields from LS-DYNA using PyDPF-Core
hbolandi
hbolandi Member Posts: 24
10 Comments Name Dropper
I would like to extract Principal stresses, von Mises stress and directional displacements fields from LS-DYNA using PyDPF-Core. Below is my implementation, but currently, I can only plot one displacement field, and it’s unclear which type of displacement it represents. Additionally, when trying to extract von Mises stress, I encounter an “AttributeError: ‘CommonResults’ object has no attribute ‘von_mises_stress’.”
path0 = r'C:\my_path'
path = os.path.join(path0, "d3plot")
act_units = os.path.join(path0, "file.actunits")
ds = dpf.DataSources()
ds.set_result_file_path(path, "d3plot")
ds.add_file_path(act_units , "actunits")
model = dpf.Model(ds)
print(model)
cpos_list = ['xy' ,'xz', 'yz', 'yx', 'zx', 'zy', 'iso']
cpos = cpos_list[0]
cpos =[(1, 1, 50),
(10, 10, 0),
(0, 1, 0)
N = model.results.stress(time_scoping=[12]).eval()
u = model.results.displacement(time_scoping=[12]).eval()
eqv_stress = model.results.von_mises_stress(time_scoping=[12]).eval()
fields_d_= u[0]
pl = DpfPlotter(notebook=False, off_screen=True)
Add the field to the plotter
pl.add_field(fields_d_, model.metadata.meshed_region,how_edges=True, opacity=0.8,
show_max=True,show_min=True,label_text_size=10)
output_image_path_d = os.path.join(os.getcwd(), 'Visualizations/disp.png')
pl.show_figure(cpos=cpos, screenshot=output_image_path_d,auto_close=False)
«1
  • hbolandi
    @hbolandi said:
    @Ayush Kumar, I would like to extract Principal stresses, von Mises stress and directional displacements fields from LS-DYNA using PyDPF-Core. Below is my implementation, but currently, I can only plot one displacement field, and it’s unclear which type of displacement it represents. Additionally, when trying to extract von Mises stress, I encounter an “AttributeError: ‘CommonResults’ object has no attribute ‘von_mises_stress’.”
    print(model)
    cpos =[(1, 1, 50),
    (10, 10, 0),
    (0, 1, 0)
    fields_d_= u[0]
  • Erik Kostson
    Erik Kostson Member, Moderator, Employee Posts: 327
    Not sure about all the questions.
    But if yo do print(model)
    Then we can see what results are included:
    e.g.,
    -  velocity: Nodal Velocity
     -  acceleration: Nodal Acceleration
     -  stress: Elemental Stress
     -  stress_von_mises: Elemental Stress Von Mises
     -  plastic_strain_eqv: Elemental Plastic Strain Eqv
     -  total_strain: Elemental Total Strain
    So as shown above the VM stress is say model.results.stress_von_mises and not von_mises_stress.
    Hope some of this helps
  • Ayush Kumar
    Ayush Kumar Member, Moderator, Employee Posts: 482
    Thanks @Erik Kostson for the solution.
    @hbolandi you tagged the wrong Ayush :smile:
  • hbolandi
    @Erik Kostson thanks for your response! The model displayed below. It might be due to the PyDPF-Core version, but for me, it's showing as von_mises_stress. Any thoughts?"
    Available results:
    - global_kinetic_energy: Unknown Global Kinetic Energy
    - global_internal_energy: Unknown Global Internal Energy
    - global_total_energy: Unknown Global Total Energy
    - global_velocity: Unknown Global Velocity
    - node_initial_coordinates: Unknown Node Initial Coordinates
    - node_coordinates: Unknown Node Coordinates
    - node_velocity: Nodal Node Velocity
    - node_acceleration: Nodal Node Acceleration
    - von_mises_stress: Elemental Von Mises Stress
    - effective_plastic_strain: Elemental Effective Plastic Strain
    - displacement: Nodal Displacement
  • hbolandi
    @Ayush Kumar Sorry for the wrong tag. Do you have any thoughts on how to extract principal stresses and directional displacements from LS-DYNA using PyDPF-Core?
  • Erik Kostson
    edited September 2024
    Hi
    For principal stresses not sure (perhaps we need to calculate from stress tensor).
    For directional displacement say z-dir., see below
    Hope it helps (not sure if you can plot these :))
    displacements = model.results.displacement(time_scoping=[22])
    fields = displacements.outputs.fields_container()
    arvm=fields[0].data
    print(arvm[0][2]) # for z for x - arvm[0][0], etc.
  • Ayush Kumar
    @hbolandi as @Erik Kostson points out, for principal stress you need to calculate it from the stress tensor. Pass the tensor as the input to the following operator to get principal stresses:
  • Ayush Kumar
    @hbolandi for displacements you can use component selector on the displacement vector, refer to operator help.
  • hbolandi
    @Erik Kostson fields = displacements.outputs.fields_container() raised the following error:
    AttributeError: 'FieldsContainer' object has no attribute 'outputs'
  • hbolandi
    @Ayush Kumar thanks for your response! I tried using stress_fields = stress.outputs.fields_container() to calculate the stress container, but I encountered the same error as with the displacement field: AttributeError: 'FieldsContainer' object has no attribute 'outputs'.
  • Ayush Kumar
    @hbolandi looking at your code above, the following are already field containers, you can pass those directly to the code snapshots in my above posts.
  • hbolandi
    @Ayush Kumar thanks for your response! I tried to plot the first principal stress filed using the code below, but encountered this error: "AttributeError: 'Output' object has no attribute 'name' " which is originated from pl.add_field
    op = dpf.operators.invariant.principal_invariants_fc()
    op.inputs.fields_container.connect(N)
    my_fields_eig_1 = op.outputs.fields_eig_1
    my_fields_eig_2 = op.outputs.fields_eig_2
    my_fields_eig_3 = op.outputs.fields_eig_3
    pl.add_field(my_fields_eig_1, model.metadata.meshed_region,how_edges=True, opacity=0.8,
    output_image_path_d = os.path.join(os.getcwd(), 'Visualizations/S1.png')
  • Ayush Kumar
    @hbolandi parenthesis are missing:
  • hbolandi
    @Ayush Kumar Nice catch!
    After adding the parentheses, I attempted to plot the stress fields as described in my earlier post. However, I encountered the following error:
    server_meet_version_and_raise
        raise dpf_errors.DpfVersionNotSupported(required_version, msg=msg)
    DpfVersionNotSupported: called from name
    I checked my dpf.core version, and it is the latest one (0.13.0). Any thoughts on this?
  • Ayush Kumar
    @hbolandi check your server version with the following command and check for compatibility with ansys.dpf.core version.
    https://dpf.docs.pyansys.com/version/stable/getting_started/compatibility.html
    dpf.SERVER.info
  • hbolandi
    @Ayush Kumar I am using ANSYS 2022R2. According to the requirements from the link you provided, I should have DPF server version 4 and DPF core version 0.10.0 or later, which I already have. That being said the server and dpf versions should be compatible.
  • Ayush Kumar
    @hbolandi 22R2 was way too old for DPF to work with LS-Dyna results. I would suggest using 24R2 in case you have 24R2 installed. Below are the commands to connect to a 24R2 server. Another option is installing a standalone DPF Server. Link below.
    server = dpf.start_local_server(ansys_path=r"C:\Program Files\ANSYS Inc\v242")
    https://dpf.docs.pyansys.com/version/stable/getting_started/dpf_server.html
  • kanchan_cadfem
    kanchan_cadfem Member Posts: 20
    10 Comments First Anniversary 5 Likes First Answer
    @hbolandi, if you prefer to use some lightweight solution there is standalone DPF
    https://dpf.docs.pyansys.com/version/stable/getting_started/dpf_server.html#install-dpf-server
  • hbolandi
    @Ayush Kumar I Installed ANSYS 2024R2 and checked its compatibility with ansys.dpf.core version. This is my code:
    ``` path0 = r’C:\Users\my_path’
    cpos =[(1, 1, 50),
    (10, 10, 0),
    (0, 1, 0) ]
    my_fields_eig_1 = op.outputs.fields_eig_1()
    my_fields_eig_2 = op.outputs.fields_eig_2()
    my_fields_eig_3 = op.outputs.fields_eig_3()
    print(my_fields_eig_1)
    pl.add_field(my_fields_eig_1[0], model.metadata.meshed_region,how_edges=True, opacity=0.8, show_max=True,show_min=True,label_text_size=10) ```
    It raised error below:
    IndexError: boolean index did not match indexed array along dimension 0; dimension is 2151 but corresponding boolean dimension is 717
  • Ayush Kumar
    @hbolandi there is known bug where the LS-Dyna stress results are reported like shell layers results even for solid elements, this bug has been fixed and the bugfix should be available in the next release. For now, you can use a workaround, where you pass all your stress results through the change_shell_layer operator, so it can strip down all the inconsistency in results. The following should work:
    layer = dpf.operators.utility.change_shell_layers(fields_container=my_fields_eig_1, e_shell_layer=0, mesh=model.metadata.meshed_region)
    layer_fc = layer.outputs.fields_container_as_fields_container.get_data()
    pl.add_field(layer_fc[0], model.metadata.meshed_region)
  • hbolandi
    @Ayush Kumar Thanks for your solution! it worked both for principal stress and displacement components. could you also guide me know how to extract von Mises stress filed.
  • Ayush Kumar
    @hbolandi please refer to DPF operators help document. You can search for keywords to get the right operator.
    https://dpf.docs.pyansys.com/version/stable/operator_reference_load.html
  • hbolandi
    @Ayush Kumar Thanks for your response! Based on the link you provided I implemented the code below.
    path0 = r'C:\Users\my_path
    cpos =[(1, 1, 50), # Camera position (X, Y, Z)
    (10, 10, 0), # Target point (X, Y, Z)
    (0, 1, 0) ]#
    op = dpf.operators.result.stress_eqv_as_mechanical() # operator instantiation
    op.inputs.time_scoping.connect([12])# optional
    op.inputs.data_sources.connect(ds)
    fields_container_eqv = op.outputs.fields_container()
    meshes_container = op.outputs.meshes_container()
    layer_eqv = dpf.operators.utility.change_shell_layers(fields_container=fields_container_eqv, e_shell_layer=0, mesh=model.metadata.meshed_region)
    layer_fc_eqv = layer_eqv.outputs.fields_container_as_fields_container.get_data()
    pl.add_field(layer_fc_eqv[0], model.metadata.meshed_region,how_edges=True, opacity=0.8,
    image_path_d = os.path.join(os.getcwd(), 'Visualizations/von_Mises.png')
    But it through the following error:
    DPFServerException: stress_eqv_as_mechanical:431<-error code 4:DPF error - runtime error: dpf core function call; remove_unnecessary_label:461<-logic::if:475<-Rescope_fc:460<-logic::if:474<-merge::weighted_fields_container_label:459<-eqv_fc:458<-logic::if:473<-elemental_nodal_To_nodal_fc:457<-S:455<-averaging from Elemental to ElementalNodal is not implemented
  • Ayush Kumar
    @hbolandi sorry, I just realized the previous operator is meant for APDL results for LS-Dyna you can use the following:
  • hbolandi
    @Ayush Kumar Thanks for your response! If I want to take the maximum stress over time should I implement a loop to iterate over all time steps to take the max or is there a simpler way?
  • Ayush Kumar
    @hbolandi, use the operator min_max_by_time(), there are various min / max operators in DPF, search for min_max in the operator help. Looping over will cost time and you lose the benefit of using DPF.
  • hbolandi
    @Ayush Kumar thanks for your help. Below is a snippet of my implementation using the min-max operator. However, it returns NaN for the stress values in the von Mises stress field. Any comments?
    op1 = dpf.operators.result.stress_von_mises()
    op1.inputs.data_sources.connect(ds)
    fields_container_eqv = op1.outputs.fields_container()
    op = dpf.operators.min_max.min_max_by_time() # operator instantiation
    op.inputs.fields_container.connect(fields_container_eqv)
    my_min = op.outputs.min()
    my_max = op.outputs.max()
    layer_eqv = dpf.operators.utility.change_shell_layers(fields_container=my_max, e_shell_layer=0, mesh=model.metadata.meshed_region)
    output_image_path = os.path.join(os.getcwd(), 'Visualizations/von_Mises_max.png')
    pl.show_figure(cpos=cpos, screenshot=output_image_path,auto_close=False)
  • Ayush Kumar
    @hbolandi if you are doing a min_max, you don't need to pass the fields container through the layer operator, you can skip that part.
  • hbolandi
    @Ayush Kumar I directly passed my_max into the plot operator and still have the same issue. Here is how I did it:
    pl.add_field(my_max[0], model.metadata.meshed_region,how_edges=True, opacity=0.8,
  • Ayush Kumar
    @hbolandi then you need to debug each line and see where the data disappears. Print the field in my_max to check if there is sensible data in there, if yes, go a level up and see the field for stress.
