How to extract contact gap using PyDPF
Vishnu
edited September 2024 in Structures
A similar procedure could be adapted for mechdpf using python results as well.
The method below uses getattribute which makes the code very generic for extraction of various result fields.
We can typically modify the result_name (in line 8) while keeping the rest of the code intact, effectively serving as a template.
  • Vishnu
    import matplotlib.pyplot as pyplot
    from ansys.dpf.core.plotter import DpfPlotter
    # Inputs
    rstpath = r"Your path to \file.rst"
    result_name = "contact_gap_distance"
    # data source
    my_data_sources = dpf.DataSources(rstpath)
    # model
    my_model = dpf.Model(rstpath)
    # mesh
    my_mesh = my_model.metadata.meshed_region
    # Time List
    my_time_scoping = (
        dpf.operators.metadata.time_freq_provider(data_sources=my_data_sources)
        .outputs.time_freq_support.get_data()
        .time_frequencies.data_as_list
    # all available results
    all_results = dir(dpf.operators.result)
    # Get result operator
    result_operator = dpf.operators.result.__getattribute__(result_name)
    # Field Containers at ns
    result_field_container = result_operator(
        time_scoping=1,
        data_sources=my_data_sources,
        mesh=my_mesh,
    ).outputs.fields_container.get_data()
    # Field Containers at all mesh
        time_scoping=my_time_scoping, data_sources=my_data_sources, mesh=my_mesh
    #convrting to nodalresults
    result_field_container = dpf.operators.averaging.to_nodal_fc(
        fields_container=result_field_container,
        mesh=my_mesh,
    # First Field usually field corresponding to first time scoping
    resultfield = result_field_container[0]
    # Chain Multiple operators here if you want########example below
    # minmax
    min_max_op = dpf.operators.min_max.min_max_fc(result_field_container)
    min_field = min_max_op.outputs.field_min()
    max_field = min_max_op.outputs.field_max()
    # Scoping nodes or elements
    result_scoping = resultfield.scoping.ids
    # print result at all scopings and results corresponding to it
    result_scoping.sort()
    for scoping in result_scoping:
        try:
            print(
                "result at scoping -->",
                scoping,
                "is -->",
                resultfield.get_entity_data_by_id(scoping),
        except:
            print("issue in extracting result for -->", scoping)
    # plot the field on your mesh
    pl = DpfPlotter()
    pl.add_mesh(my_mesh)
    pl.add_field(resultfield, show_max=True, show_min=True)
    pl.show_figure()
    # graph plot using matplotlib
    pyplot.plot(my_time_scoping, max_field.data_as_list, "ro", label="Max")
    pyplot.plot(my_time_scoping, min_field.data_as_list, "bo", label="Min")
    pyplot.xlabel("Time (s)")
    pyplot.ylabel("Result (unit_of_result)")
    pyplot.legend()
    pyplot.show()
    @Vishnu ,
    Seems like there is an operator for this: op = dpf.operators.result.contact_gap_distance()
    Why are you using the more obscure method of:
    result_operator = dpf.operators.result.getattribute(result_name)
    Is there a difference in what you are doing vs. the documented operator?
  • Vishnu
    @Mike.Thompson
    This method tends to be quite generic. The customer can usually modify the result_name (in line 8) while keeping the rest of the code intact, effectively serving as a template for users.
