How to undo a move in PyAEDT
I am doing simulations with objects moved to hundreds of different locations using move() but this results in a long chain of "Move" in the model hierarchy which appears to slow down the simulations over time. How do I delete/undo these moves in Python so that there is only one move in the hierarchy per object at a time? Is it faster to delete and redraw the object every time? Thanks.
  • James Derrick
    James Derrick Administrator, Employee Posts: 358
    admin
    Hi @aetherael thank you for your question, I have tagged some of our AEDT experts who might be able to get you the answer you need.
    @Samuel Lopez
    @peng.han
  • vamsi.krishna
    vamsi.krishna Member, Employee Posts: 1
    Hello Aetherael,
    Can you please explain if you are moving to object to different locations by keeping parent object as a reference?
    My guess is that you are trying to create a pattern of objects with similar geometrical identity. Am I correct?
    Deleting and redrawing may not be a good idea as process might take more time for deletion in every instance.
    Please provide above details and let me understand more to help you better.
    Thanks.
    Vamsi
  • aetherael
    aetherael Member Posts: 2
    Hi Vamsi,
    The problem was solved by moving the object by variables in HFSS and editing the variables with PyAEDT.
    Thanks
