Say we have two nodes, 1, and 2. Using scripting, how can one define a Coordinate system with X axis point along a direction vector between two nodes (origin on 1st node)?
There are many ways of doing this, but one sample example below , uses 2 named selections (node 1 and 2) and the difference vector between them giving the direction of the X-axis.
This is just an example and can be used and tailored perhaps as needed to suit purpose:
model=ExtAPI.DataModel.Project.Model # refer to Model analysis = model.Analyses[0] solution = analysis.Solution ##get 2 NS node 1 and 2 ncs1=ExtAPI.DataModel.GetObjectsByName("MYNCS1")[0] mncs1=ncs1.Location.Ids ncs2=ExtAPI.DataModel.GetObjectsByName("MYNCS2")[0] mncs2=ncs2.Location.Ids ##get mesh nodes of NS MeshData=ExtAPI.DataModel.MeshDataByName("Global") node1= MeshData.NodeById(mncs1[0]) node2= MeshData.NodeById(mncs2[0]) ## vector = node1-node2 vec=[] vec[0]=node2.X-node1.X vec[1]=node2.Y-node1.Y vec[2]=node2.Z-node1.Z ## define UCS testCS = ExtAPI.DataModel.Project.Model.CoordinateSystems.AddCoordinateSystem() testCS.CoordinateSystemType = CoordinateSystemTypeEnum.Cartesian testCS.OriginX = Quantity(node1.X,"m") testCS.OriginY = Quantity(node1.Y,"m") testCS.OriginZ = Quantity(node1.Z,"m") testCS.PrimaryAxisDirection=Ansys.ACT.Math.Vector3D(vec[0],vec[1],vec[2])
Another way is by selecting to nodes graphically (1st node selection is the origin, and 2nd node is used together with 1st for the alignment):
model=ExtAPI.DataModel.Project.Model # refer to Model analysis = model.Analyses[0] solution = analysis.Solution cursel=ExtAPI.SelectionManager.CurrentSelection.Ids selectionor = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.MeshNodes) selectionor.Ids=[cursel[0]] # first node is origin testCS = ExtAPI.DataModel.Project.Model.CoordinateSystems.AddCoordinateSystem() testCS.CoordinateSystemType = CoordinateSystemTypeEnum.Cartesian testCS.OriginLocation = selectionor selection = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.MeshNodes) selection.Ids=cursel # both nodes needed for x-axis def. testCS.PrimaryAxisDefineBy=CoordinateSystemAlignmentType.Associative testCS.PrimaryAxisLocation=selection
Finally the above example can be extended to give some guidelines to the user on how to use it (e.g., to select 2 nodes, etc. - this is done via a text message box)
import clr clr.AddReference('System.Windows.Forms') from System.Windows.Forms import MessageBox model=ExtAPI.DataModel.Project.Model # refer to Model analysis = model.Analyses[0] solution = analysis.Solution cursel=ExtAPI.SelectionManager.CurrentSelection.Ids selection = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.MeshNodes) selection.Ids=cursel # both nodes needed for x-axis def. if len(selection.Ids)==2: selectionor = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.MeshNodes) selectionor.Ids=[cursel[0]] # first node is origin testCS = ExtAPI.DataModel.Project.Model.CoordinateSystems.AddCoordinateSystem() testCS.CoordinateSystemType = CoordinateSystemTypeEnum.Cartesian testCS.OriginLocation = selectionor selection.Ids=cursel # both nodes needed for x-axis def. testCS.PrimaryAxisDefineBy=CoordinateSystemAlignmentType.Associative testCS.PrimaryAxisLocation=selection else: MessageBox.Show('We need to select 2 nodes. 1st node is the CS origin and 2nd is used for the alignmnet of the CS x-axis')
