How can I parametrize the displacement value of reaction force max and/or min in Ansys Mechanical in
parametrizing max and min values of force reaction is very simple but I don't know how to do that with their corresponding displacement values visible from "chart" graph.
Basically I would need to parametrize, for the next RSO analysis:
Fmax
Fmin
x of Fmax
x of Fmin
Thank you
Hi
You can do as in this first post - you need to find the max force and corresponding time via looping as done there, and then make these parameters (as shown in the second post).
All the best
Erik
1 -
Hi Erik,
I really appreciate your suggestion and I am sure it is the right way but, with reference to the first step, it is suitable for batch mode and I think there are many negligible info for my application that instead make the understanding, then implementation, harder.
I tried but, since I am novel in this kind of topic, I failed.
I managed to create new properties but csv files don't appear in my working folder.
If you, or someone else, have a more custom solution/code I would be very grafetul.Thank you
