I want to print a custom text at the bottom left corner of the Geometry view Panel. How can I do this?
You can use the following Python script which creates a text annotation at the bottom left corner of all panels:
#Get current Panel boundaries Pane=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.Graphics) Width=Pane.ControlUnknown.width Height=Pane.ControlUnknown.height #Define the distance of the text from top left corner identLeft = 10 identTop = Height-20 #Remove older annotations g = ExtAPI.Graphics for i in g.DrawContexts: g.RemoveContext(i) g.Redraw #Create new annotations pt = g.CreatePixelPoint(identLeft, identTop) annotationUser=g.Scene.Factory2D.CreateText(pt, "Test Annotation") annotationUser.Color = 0x000000
The text's location is measured from the top left corner of the Panel. The text is displayed across all Panels, so if you need it to be removed, you can execute the following portion of the above script:
Very useful article, thanks @Nikos Kallitsis!
