Hello All,
We have a script which records the modal natural frequencies and update the harmonic user defined frequencies. Now the problem is this script is mechanical script and we need to run it automatically by inserting it as a command snippet, so when we run a DOE each time this scripts runs automatically. How can I use this mechanical script as a command snippet, note that we are running a full method harmonic, we are not connecting the modal solution to the harmonic analysis but model will be shared.
