Error: attribute 'CurrentUnitFromQuantityName' of 'namespace#' object is read-only
ZZ.tang
ZZ.tang Member Posts: 23
ANSYS version: 2021r2 & 2023r1 mechanical
I'm trying to build an ACT APP extension in mechanical, when I tried to run it below warning shows up.
MissingMemberException
at IronPython.Runtime.Binding.PythonGetMemberBinder.NamespaceTrackerDelegate.Target(CallSite site, Object self, CodeContext context)
at System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
at Microsoft.Scripting.Interpreter.DynamicInstruction`3.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
at Ansys.ACT.Core.Extension.ReadScripts()
Extension NamedSelection_Toolbox loaded for context Mechanical.
Then I tried to modified the code, then I noticed if I just add a line like below, without any operation, the warning still shows up.
DataModel.CurrentUnitFromQuantityName
And it very strange that the same code could be run normally in mechanical scripting without any warning.
Best Answers
  • AlexGh
    AlexGh Member Posts: 29
    Try accessing the function CurrentUnitFromQuantityName via
    ExtAPI.DataModel.CurrentUnitFromQuantityName.
    Which version of Ansys are you using?
  • Landon Mitchell Kanner
    import Ansys.Mechanical.DataModel as DataModel
    ^--This is not the proper way to define DataModel. Instead do this:
    DataModel = ExtAPI.DataModel
  • AlexGh
    Hi ZZ.tang!
    The message 'attribute 'CurrentUnitFromQuantityName' of 'namespace#' object is read-only' means that the requested attribute is missing from the object. This can happen, for example, when using an extension developed for a different version of Ansys. Developers may remove or relocate certain attributes and functions of objects between Ansys versions. Could you provide a bit more context? Perhaps part of the code that gives this error?
  • ZZ.tang
    import clr
    clr.AddReference("Ans.Utilities")
    clr.AddReference('Ans.UI.Toolkit')
    clr.AddReference('Ans.UI.Toolkit.Base')
    clr.AddReference('System.Windows.Forms')
    clr.AddReference('System.Drawing')
    clr.AddReference('System.IO')
    clr.AddReference("Ansys.Mechanical.DataModel")
    Something like this cannot work in ACT APP extension
    but can work in scripting
  • ZZ.tang
    @ZZ.tang said:
    import clr
    sorry, I just checked
    the error might caused by "import Ansys.Mechanical.DataModel as DataModel"
    if I run
    and then
    it also not work in scripting
    but
    works both in APP and scripting
